Crane Cam
Date: 02/26/2018 07:50 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 10/05/2017 02:26 pm
Date: 07/30/2020 11:45 am
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Date: 09/20/2018 11:01 pm
Date: 08/20/2017 01:34 pm
  • Online today: 548
  • Guests: 343
  • Total: 343
Headliner Removal
Started by r4pinto, January 06, 2008, 10:41:26 AM
Quote from: 77turbopinto on January 06, 2008, 11:03:49 AM
The PROPER way to remove it requires the windshield to be removed, and the q-glass if they are not the 'pop-out' style.
The liner is tucked under the gaskets for the windshield, q-glass and hatch, it has hooked plates everywhere else where it ends, and it has a series of metal rods from side to side. The rods are different lengths, so you need to keep them in order.
I have found it impossible to remove a headliner without destroying it.
There are videos available that show you how to do it.
You should be able to snake a wire up there, but I think the map light has a different mount bracket that needs to go under the liner.
I have used vinyl dye to change the headliner color without removing it.
where are those videos please?
map351
You need a steam gun to get all the wrinkles and make the liner nice and tight.
That's if you want to do it right.
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
Thanks for the info Bill
I know what you're saying about the map light bracket. It took me well over a year to find one that would work, but I found one on a Ford Fairmont that is gonna work perfectly after I modified it some.
The headliner has quite a bt of stitching torn so I was gonna replace it, but for now I'll just fix it. The windshield seal is cracking so I'm gonna have to replace it but not right now.
I gotta run a wire to the map light for it to work, so I need to remove the headliner. How do I do it? Couldn't find it in the book.
