1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
Date: 02/18/2017 04:44 pm
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Bumper Guards
Date: 03/28/2017 09:27 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
  • Online today: 548
  • Guests: 484
  • Total: 484
1979 2.3 head gasket recommendation
Started by Starliner, January 05, 2008, 10:52:06 AM
XCorePintoLover
Fel Pro or anything that isn't cork. That stuffs is a bitch to get back off.
Until recently, I drove a '79 Bahama Blue 2.3 Automatic Hatch.
Is the proud mommy of a baby girl, Haylee. :D
I've heard ROL makes some thicker head gaskets to make up for the loss of material when the head is decked.
apintonut
i concur about fel pro,  but i just got a good deal on a built head and it is decked more than i was looking for who sells a thicker high performance head gasket?  if the head is decked the most u can on a 2.3 but i think it may be too much with a turbo
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
I too am a firm believer in Fel-Pro head gaskets. To clean up the mating surfaces I use a brass putty knife, and brass wire brush. The brass is easy on the cast iron. If you had a gasket failure, and any overheating, I'd take the head to have it leveled. That's $50 worth of cheap insurance.
I second that. Always used Felpro.. with nothing on it.
I'm big on the Felpro head gasket...
FrankBoss
Starliner
Wifey's 79 2.3 has some oil leaks.  One of the oil leaks is from the head gasket on the drivers side in the rear.  (I have fixed the valve cover gasket and the oil sending unit)
(Thanks to HIGH_HORSE for pointing that common leak point out)  So early this spring when the weather breaks I figure I can pull the head and fix that oil leak and change the timing belt.   Then I can more easily find any other leaks.
My question...  What brand head gasket is the best to prevent this from happening again?
FelPro ??   Other ??
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
