Date: 06/24/2020 06:12 am
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Date: 11/29/2018 10:26 am
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Date: 05/22/2018 01:54 pm
Date: 07/04/2017 03:26 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Date: 02/28/2018 09:18 am
  • Online today: 553
  • Guests: 256
  • Total: 256
How Many Different C4 Bells Were Made For Ford 2.0s + 2.3s?
Started by 77turbopinto, January 04, 2008, 03:59:56 PM
BigHoss48192
Sorry to resurrect such an old post but will the D42P bell fit as long as you have the step-down dowels?
Quote from: 77turbopinto on January 18, 2008, 08:34:44 PM
This is what I sent:
"That ''D42P'' bell will not direct bolt to a 2.3, it was made to fit the 2.0 ONLY. The ''D4ZP'' is made for the 2.3. I hope this helps."
His reply:
"it will fit the 2.3 minus 2 bolts...thanks...i,ve did it before tommy"
It appears that he knows that his listing discription is wrong/misleading, but even his reply is questionable: All 6 bolts CAN be used, so maybe he 'not did it before'?
SCAMMER!!
Poor bidders. He'll get his eventually.
Good in fo on the bells though Bill. You da man. ;D
His reply:
SCAMMER!!
Another buyer beware item!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170186185212&fromMakeTrack=true
"...yes this is the highly sought after 74 model that came on the 2.0 and 2.3 that year...D42P 7976 AA1"
I sent him a 'question' and gave him the correct info....
apintonut
the car came with c3,  but i used it for deliver pizza for 2 company at the same time so the car got well used and all my parts i got for free from a tow yard that a friend owned the same tow yard that soled me the car.  a 75 with 30,000 original for  40$. any way i would put any tranny that i came across in. i was going from a a4ld back to a c4 from a 2.0 that had came from a 72 or 73 figure 8 car. all the tranny's i put in were used and most the time i didn't know any thing about them. even if they were worked at all i put 6-7 tranny in that car.
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
Quote from: Pintony on January 05, 2008, 11:41:39 PM
Heyu Bill,
R U saying that the bell will not fit?
OR That the dowls are wrong for your 2.3???
Quote from: 77turbopinto on January 04, 2008, 08:31:15 PM
The dowel pins for the 2.0's are about .5" where the 2.3 are about .6" in diameter. Other than that, EVERYTHING else is the same.
apintonut
i ran into this with my 75. ( i went though tranny's like they were going out of style) but need to have the car back on the road for work that night and drills them out.  never had a problem. not the right way to do it but like i said i had to have the car back on the road that night
Heyu Bill,
Quote from: TIGGER on January 05, 2008, 05:25:30 PM
I'll bite... I'll go for option 2 - Final answer ;D
Sorry for the trick question, but the answer is NIETHER. Get out of the Cash Cab and start walking.
I do admire your bravery.
Now for the back story.
I scored a "D4" bell last year, put it on a shelf and thought no more of it now that I "had one."  Earlier last year, Ultimate Pinto and I gutted a 73 Wagon; he took the engine, I took the tranny. A few days ago I decided to clean the bell from the 73 because I had a "D4" and I was going to sell this "D1". As I clean it I discover it is a "D4". Now I know for a fact this came off a 2.0, so I attempted to install it on one of my spare 2.3s only to find it won't fit due to the dowel size. Then I grabbed my other "D4", and sure enough, it won't fit either. I started looking into this to find there are at least 2, maybe more "D4" bells, of which at least one will not fit a 2.3. The D4s have prefixes of "D42P", "D4ZP", and MAYBE a "D42F" and a "D4ZZ" (I have not been able to verifiy these); the "D42P" WILL NOT FIT A 2.3. This is something to look for when buying a "D4" bell. The dowel holes for a 2.0 are .480", the ones for a 2.3 are .6". All these bell part numbers will have the same middle number of "7976" and should also have some variation of "A", "AA", or "AB", possibly followed by a dash and one or two more numbers (one of mine has a "-1" the other a "-2).
I hope this helps.
No-one??
OK, here is another one:
If you wanted to install a C4 behind a 2.3 and wanted to use a stock un-altered bell and dowels, what bell would you use?
1) a "D1MP-7976-AA"
2) a "D42P-7976-AA-2"
Quote from: Mutant pony on January 04, 2008, 06:24:52 PM
I could be wrong but,  It seems to me that they used the same c-4 bellhousing.
The c-3 and c-5 bells are different and won't work on a c-4.
I used to know all this stuff but, It's been a while.
Mutant pony
'77 pinto,Reinforced stock chassis.2300,courier trans, np205 transfer,9" rear,427/430 gears
Trivia question for all us 'experts'....
Anyone?
It's not what I thought.....
People might want to find out before they buy one.
ADDED: I now sell stepped dowel pins to allow the 2.0 bell to bolt on a 2.3. PM me or see my thread in the parts for sale section.
