Date: 02/28/2018 09:37 am
Date: 12/04/2018 07:40 pm
80 pinto original
Date: 08/04/2019 10:45 am
Date: 04/30/2023 04:31 pm
Date: 03/17/2019 03:57 am
Date: 09/03/2018 08:58 am
Date: 11/05/2020 06:32 pm
Interior Parts
Date: 08/07/2017 03:59 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
  • Online today: 267
  • Guests: 248
  • Total: 248
No compression, 2.3 new cam
Started by r4pinto, December 23, 2007, 12:04:05 PM
Glad my thread is of some use to ya. Good luck on yours. I still got a few vac lines to connect & set the ignition timing, but atleast it starts & runs. Next is the bad tranny getting swapped by the good tranny sitting next to the car.  :fastcar:
Glad to hear you're getting it up & running Matt. pretty soon you'll be  :fastcar: in it.
I've been hampered by finances lately, but your thread is like a gold mine to me. Especially since I'm getting teady to do EXACTLY the same thing to mine.
The rockers fixed the problem. I sprayed some ether down the carb & she fired right up, first time. It's loud since I don't have an exhaust on her right now, and the manifold on her right now has a hole for the EGR line, but none the less it ran.
To Bill & anyone else that helped with this, Thanks alot.
I have always heard that the only engines that had the roller cam were 8 plug DIS engines.
I also heard that 93 was the change over year for the rocker/valve size change, but all I could find in my searching of parts places was showing that the change was in 95.
Well, I got to Pick N Pull today, good day for parts pulling with all parts half off. Anyways, I found an 89 Ranger & decided to pull the valve cover off the engine. Got it off to find the rockers were totally different from the 93 engine.  Bill, I went ahead & took your advuce from a previous post & grabbed the lash adjusters since I was concerned mine were any good. Anyways got 8 rockers & 8 lash adjusters for 9 bux.
Tip for those going to get a roller cam from a Ranger. Contrary to what some have heard, it DOES NOT matter if it's a 4 or 8 plug head. What makes the difference is the style of roller rocker. The one that can be used in the Pinto 2.3 looks closer in appearance to the slider rocker  in the engines. Just a basic looking roller rocker with no fancy curves on the side. The one in the newer Rangers, 93 & up  for sure, not sure on the rest, are wider at one end than the other as you're looking at them, and as I found out WILL NOT fit over the valve stems, thus keeping the valve open.
Well if the roller cam from an 8 plug head will work then i should go back and get that ranger engine. The guy was just gonna give it to me but i was sure the cam from the 8 plug head wouldnt work  :o What about the head itself, will it accept the pinto intake?  Im not sure what year it is... but it needs its head rebuilt anyways so if itd work i could just switch them out. That'd be nice :)
Well, it looks like I'm gonna just have to take an old slider follower that came from the engine to make sure the roller follower I find will work.
Quote from: pintoguy76 on December 25, 2007, 02:23:08 PM
Yes they are but ive always hear to make sure and get the one from a 4 plug head and not one from an 8 plug head. There were both with a roller cam, but like i said i dont know why its a problem. I think it was explained to me but i dont remember what it was. You might be able to make it work i dont know....
Both of the ones we have are from 8 plug heads; both cars run fine.
BTW: I have not found any other VIN engine codes to say there are different rockers or cams. I CAN say that the 1995 and later followers are different.
Unless the firing order is different on the 8 plug head, I can't see why it wouldn't work. The geometry looks the same.
Plenty of 2.3T owners are using the Ranger roller cam with no probs
Yes, it sure did. Is it the rockers that are different on the 8 spark plug head?
I think someone may want to post this info somewhere. It would have been useful to me, as well as others & kept me from waisting $30 on the cam & rockers I got.
Did the engine the cam came from have 8 spark plugs? The 8 plug cam wont work (i dont know why) I can get a 2.3 ranger engne (with cam and all) for free but it has the 8 plugs. :(
92/93 Mustang eh? Thanks for the tip man. I'll look for a Mustang first since I gotta go through the Fords to get to the trucks anyways.
I have a 92/93 Mustang 2.3 engine with the larger valve stems and roller rockers.  The rockers are cast or forged.
I have a 98 Ranger 2.5 engine with the skinner valve stems and roller rockers.  The rockers are stamped heavy sheet metal.  The slot in the rocker that fits around the valve stem is too narrow to fit around the earlier larger valve stems.
If your valve stem fits in the rocker slot, I suspect you have the correct rockers.  I have read that the Ranger got the roller rockers a few years before the Mustang, so that Parts America list above may be correct.
I measured a lifter out of a 79 Pinto 2.3 with a slider cam and out of the roller Mustang 2.3 and the lifter for the roller was about 0.070" shorter than the slider lifter.  My engine stash is not in the best of shape so this may be a misleading clue but worth checking out.
Quote from: 77turbopinto on December 23, 2007, 08:25:15 PM
The fact that the CAMS have the same number is good.
I could not find any information to show that there were 2 different roller cams. If this is true, all you need are the correct roller followers. Also, I did a search a while back and found that NAPA had ONE part number for ALL SLIDER 2.3 cams. At the time I did not check on the rollers.
Keep in mind that your donor might not have had the original engine in it.
Please don't take this the wrong way: are you sure they are installed correctly? I have seen a photo where the followers were installed backwards.
Yeah, I have the rounded end over the lifters & the flat end over the valve stem. I figure what I'll do when I go to the junkyard to get the rockers I'll just take one of the original rockers that came out of the engine so I have something to compare it to. It's not going to be until Friday when I go to Pick N Pull, so I have enough time to get my tools & junk together.
DON'T go by partsamerica.com!!  ALL wrong with the info on Pinto followers! It shows the same roller one as the Ranger, but when you click on the tab to show all applications, it shows: 87 Areostar, 91 to 93 Mustang, 87 to 94 Ranger.
Best I can tell 94 is the change over year for the valves, but I am not sure.
Well, the information I found on partsamerica.com seems to be flawed. I just checked autozone.com & it shows the same follower number for 88 & 93 rangers, but a different one for 77 Pintos.
Well, I actually did check the cams & the numbers were the same for the two years I checked, both 88 & 93. Shows the same cam for 87-01 Ranger, but the followers for a 77 Pinto & 88 Ranger show to be the same part number.
The valve stem and the adjuster hold the follower in alinement with the cam. If the slots on them are too narrow you could have binding (as you know), if they are too far apart the follower will not track correctly. IMHO: Get the correct ones.
BTW: Just because the cams LOOK the same does not mean they ARE the same. Check the part numbers at the dealership or the parts place to see if they take the same one. Use the part numbers for the followers to find the year they made the change.
I might try that just to see what would happen. If I do it myself I'm not out anything, just a little time to do it. Dunno, we'll see.
If you have a friendly machine shop, they'll likely machine the rocker tips to fit your valves for a couple bux each. That'll save you a JY trip, and depending on the yard, maybe even a few bux. Depending on your paitence level, you COULD file them out yourself.
Myself, I'll take them to the machinist at work, and have him cut them...He'll do it for a six-pack.  :cheesy_p:
Looks like the cams are the same, so after I get my next paycheck I'll go after 8 roller rockers from an 88 Raonger 2.3 I'll take one of the old rockers with me to see if it will fit. Sux I gotta take the valve cover back off, but atleast I don't have to go all crazy & tear down the whole friggin thing again.
From what I have read, the LATER followers are made for the NARROWER valves. I don't know what date the change was made. IF you have the ones for the narrow valve stems, I would think it would hold the valves open like you mention. You should be able to look at them to see how they are seated on the valve, if not just pop one back out and check it.
Stuff happens, just take your time and figure it out.
Don't go back to the slider unless you have to. I would check with a parts place and see if they list a different CAM/followers for 92 to 93. If they show the same cam then all you need are the correct followers. BTW: Find a used set.
I gots me a major problem with my 77 sedan. I just got done replacing the camshaft & followers with a roller cam from a 93 Ranger and I have no compression. The timing marks are right on the money.. Already checked them about 10 times & they're perfect. I read somewhere on here the early model 2.3s have bigger valve stems than the newer models.
Could that be my problem, which could cause the valves to not close? (if I am guessing right that is). If so, how do I remedy this without getting a slider cam from another 2.3 & starting from scratch?
