Date: 09/15/2019 12:28 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
Great Cruise wagon
Date: 12/17/2016 03:39 pm
Date: 01/28/2017 12:30 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Date: 09/09/2018 03:22 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
  • Online today: 899
  • Guests: 579
  • Total: 579
2.0 carb parts (cheap carb idea)
Started by apintonut, December 09, 2007, 12:42:22 AM
71hotrodpinto
Hey there, yah Holley used to make a performance 350cfm progressive that works like the stock carb. However its long since out of production, and I think in the last 4 years on ebay constantly ive only seen about 2 or maybe 3. They look like a regular 350 at first glance, but you can tell by the linkage. Looks just like a stock carb.
Don't be confused with the holley "replacement" that i see on ebay all the time. Its just a stock emission carb made by Holley
If you build the engine to support it ,have a standard trans, 3:40 or higher numerical rear end , you could get an esslinger single plane intake and drop a 350 on it and have a very peppy lil runner @ the higher rpm ranges. Prob only get you 15 20 hp Max if you have the cam to support it.
I had my 2.0 on a 390 6299 Holley and a ported offy intake with a C4 and a 3.18 rear. Very peppy at lower rpms. Later i switched to a Weiand intake and didnt notice much differance at the higher rpms but the lower was a bit softer.
I bet i didnt ever have more than 125hp on it. But i cant say that i ever tuned it right either.
That said the 2.0 is very hard to keep streetable naturally aspirated at higher HP levels ,unless you turbo it.
PINTONY???!!  :)
Got to get now talk later ;)
Good luck
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
earthquake
holley does not make one that I know of.
apintonut
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
