Misc. Pinto parts
Date: 11/09/2019 04:25 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Date: 10/03/2018 02:00 pm
Date: 10/01/2020 02:00 pm
Date: 05/13/2021 05:33 pm
Date: 04/30/2023 04:31 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Date: 10/10/2019 10:02 pm
Date: 02/11/2020 12:09 am
  • Online today: 553
  • Guests: 202
  • Total: 202
need carburetor help for 79 pinto
Started by SD44, December 07, 2007, 06:16:16 PM
It should help out. Only thing is you will prolly want to get some gas tank sealer to put in there afterwards. Better to seal it now then have to drain the tank, clean it & seal it later.
Theres a radiator shop here that repairs gas tanks also. I believe they can boil the tanks out and repair them just like they can the radiators. Would that get any particles and varnish out of the tank?  Sure would be nice to get that crap cleaned up.
PintoGuy76,
          oh.
The particles in the carb were on the other 76. The pump went bad on the 79 which i just rebuilt the carb on. I was talking about the 76 because of the comment r4pinto made about rust plugging up his carb.
PintoGuy76
         The everclear will not get rid of the rust....It will disolve the varnish...If you think you have that much rust then you would be best to pull the tank. My guess is the particals are varnish. An excessive rust buildup would clog the pickup sock in the tank. Maybe that is what happened here. Did you try blowing some air back into the fuel tube before you deemed the fuel pump as bad?
Thanks for the tips high horse. Just curious tho how does the everclear cleans the rust from the tank? Also, i had a run of bad luck last night. After i rebuilt the carb on my 79 i went to put it on and the brand new electric fuel pump i put on went bad! So i couldnt even start it to see how well i did. I had the parts store order a new one and now im getting ready to go get it. Its raining out, with the threat of an ice storm again. (that was a mess last year, no power here for 2 weeks so everyones freaking out) I may brave the cold rain and put it on anyways, im anxious to get this thing done. Ive got a chevy to work on after this projects done.  :amazed: :rolleye: :surprised:
PintoGuy76,
      It sounds like you have plenty of filters. Go to the liquer stoe and buy a botle of everclear and unload it in that tank that will speed up your tank cleaning process. Concentrate on that filter by the fuel pump. A canister filter is easier to clean. It takes time. Or you can pull the tank and get it over with.Check your advance flyweights for the jerk in the acceleration.
Yea it is pretty easy and it does make a huge difference. I have 2 filters in line. One is behind the eletric fuel pump and the other is in the carb. They are both oddly enough the same filter. I dont have much faith in those tho because i still get tons of that rust from the tank in the bottom of the float bowl. How it gets by two filters is beyond me. It is the reason i think that i get a jerk in acceleration (that goes away when i hit the secondaries.) I cleaned the rust out  last time and the jerking when away and now its back so i suspect the rust again. At this point i am not sure what to do, go with one of those silver in line canister filters? Theres got to be something we can do to filter out the rust.
pete laxton
my 2.8 v6 carb was taken to my local napa dealer. they sent it off and it was factory rebuilt. wonderful job. however i left the return springs on the carb they was not on the carb when i got it back.
Atleast it's easy enough to do lol. The first carb rebuild I did was on my Pinto & it actually ran good. That is until the rust in the gas tank plugged it up & left me stranded in West Virginia.
I just ordered a carb kit for my 79 today ill get it in the morning. rkk is right. The kit is 30 bucks. Hoping to have this carb done and ready to go back on tomorrow. Ive switched carbs between my 76 and the 79 way too many times and im tired of it lol.
rkk
You can find probably find a good one on this site.  Look in parts for sale or post in parts wanted.
If not places like Oriellys and Auto Zone sell kits for about $29 ;D
1976 TURBO PINTO
SD44
anyone know of a retailer that sells a reproduction or remanufactured carb for a 79 2.3?  where can i get a carb kit reasonable?  they're around $75 here.
