95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 05/18/2020 10:22 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Date: 07/13/2018 02:21 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
Date: 12/09/2016 08:34 am
Date: 04/10/2017 07:30 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 08/22/2018 09:23 am
  • Online today: 367
  • Users: 1
  • Guests: 102
  • Total: 103
  • rob289c
Muffler question
Started by hellfirejim, November 05, 2007, 07:53:14 PM
map351
I made a few brackets of the frame connector and the rear seatbelt mount plate. On the pipe i used Thermotec wrap, 1 wrap of Thermotec SS hose clamp to the bracket.
I'll take a pic later..
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
That's cool!!  so what did you use for hangers for the muffler?
map351
Not bad on the noise.
I bought 2 on eBay for 52.00 Bux, sold one for 35 Bux!
Jan has the other on his Toyota Celica with the 2.3 turbo,T5 just went a 12.70 through the muffler...
73 2.3Turbo Pinto
Pinto FiberGlass
Just how quiet is that thing???
What I am going to put on now will only last until the turbo goes on so I don't plan to invest a boat load of money but it does have to be reasonably mellow.
map351
73 2.3Turbo Pinto
Pinto FiberGlass
That looks ike your standard 4" x 9" turbo muffler.....
map351
Jim
I have 3" from the turbo to the bumper with a single chamber flowmaster. Lotta room, i used a header collector (3 bolt) in front of the muffler makes it easy to drop.
73 2.3Turbo Pinto
Pinto FiberGlass
Since I am running 15s on the back and will have a slight nose down atitude I was hoping for enought room to run it in the location unde the pass side rear seat.
Once I get it back down on the ground [up on stands] I will have to measure and see what I come up with.
Depending on the size of the muffler(s), you can get them under the back seat.
I just got all the pipes and mandrel bends to put a 3" system in my Tan Pinto.
Bill,
I saw that too and was wondering if that was my only possibility.  BTW: I am running 2.5" pipe.  : )
The stock location is on the pass. side next to the gas tank, just in front of the rear bumper.
I have seen a 2 in/out that might even fit there.
This is not your standard what kind of muffler are you using, etc, etc but was triggered by looking under the car wondering just where the hell do you put the muffler????   Don't forget I have frame connectors that stick down about 2".
Since I now have it running and it is loud a muffler would be a good thing.  I welcome all opinons.
thanks
