Date: 04/21/2017 02:03 pm
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Date: 08/08/2017 01:44 pm
Date: 03/21/2017 07:47 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
hood for a 79-80
Date: 11/30/2018 10:55 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
78 windshield trim
Date: 02/01/2020 08:46 am
Date: 10/05/2017 02:26 pm
  • Online today: 452
  • Guests: 310
  • Total: 310
Pump to Carb fuel line
Started by dave1987, October 26, 2007, 01:36:42 PM
Pintoguy76. That's what I'm using now, the brass fitting with fuel injection hose connected to it. It works just fine, I just wanted to make some sense of my engine bay by putting an original shaped metal fuel line in.
I could always put the one I pulled from the mustang in it, but it would mean putting it on and taking it off with vise grip pliers.
Ive been told copper is a big no-no for fuel lines. It corrodes real bad and leaks. It was referred to as a "death wish" by one person. I went to a similar place here and just bought a brass barbed fitting and screwd into the pump and used a hose to connect it.  It takes a special fitting not just any brass fitting but the place you're talking about should know what you need.
Quote from: dave1987 on October 26, 2007, 01:36:42 PM
...I used teflon tape counter-clockwise around the threads.
IIRC: That is a flared fitting so the threads have nothing DIRECTLY to do with the sealing, and if there are ANY defects in the mating surfaces, it will leak.
I picked one up from a salvage yard here in Idaho, pulled it off a mustang with a 2.3 carb'd motor.
Well the one I pulled off the car had a trashed securing nut that screws into the fuel pump. I went to an industrial copper/brass supply and fabrication shop and they re-fabricated the fuel line for me with a new nut, but they used copper instead of steel fuel line.
When I got home to install it, it all matched up fine, however it leaks like a beast around the nut. It doesn't look like it is just coming out around the nut though, but also around the tube that goes through the nut. Is this a defect from when they fabricated it or am I putting it on wrong? I used teflon tape counter-clockwise around the threads.
