Automatic Wagon
Date: 06/14/2019 11:22 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
Date: 08/30/2018 12:59 am
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 03/30/2021 12:29 pm
Date: 01/19/2020 09:06 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 08/20/2017 01:34 pm
74 hood
Date: 07/03/2017 03:46 pm
  • Online today: 553
  • Guests: 173
  • Total: 173
Hot Rod Pinto Motor
Started by turbo toy, October 21, 2007, 10:27:05 AM
Beautiful work.  Looking forward to seeing more of the build up.
Just wanted to make sure that you saw Brad Calhoun's main girdle.  He may have some useful input for you.
http://i6.photobucket.com/albums/y250/jbcalhoun/DSCblockgirdle2.jpg
http://www.fordpinto.com/smf/index.php/topic,6020.0.html
turbo toy
Dave Flanders is making 1000 HP and Don Nase made over 1200 HP on gasoline, so I think it's do-able on alky. I'm building a main girdle that will tie the caps to the pan rail to help keep them from walking and add strength to the block, and the block will also be solid filled. Since it's an alky motor, no coolant or intercooler is needed.
Pinto Pro
Joe Morgan was making about 780 to 840 horsepower on a stock block a while back, so I think its doable....but 1000+ is pushing it!! LOL....more power to you if it makes it.
71hotrodpinto
Quote from: turbo toy on October 23, 2007, 08:29:55 PM
I plan to turn the motor 94-96000 Rpm and it should put out around 14-1500 HP.
Dam near 100,000 rpm!!! that ought to do near 700mph in the 1/4. You have a pilots liscense??  :lol: :lol: :lol:
Serioulsy that is one expensive peice. NICE!!!
Can the block hold that much??? I know they are good to around 700ish HP but double that? HOLY SHOMOLIE!!!!
What about the Tall deck aluminum block that the midgets run??
Have some serious Fun!
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
turbo toy
Quote from: Pintony on October 22, 2007, 09:38:43 AM
OK,...
Now that I have stopped drooling over the photos of your engine...
R U going for the stroker 2.5 crank or 2.3 crank??
What rods R U planning to use??
Roller Cam??
I still drool over it and it's mine. It's a pretty straight forward deal. It's a .030 over stock stroke, 2.3, alcohol motor. The build up is:
Turbo block
Moldex billet crank
GRP rods
CP pistons
ARCA head
Esslinger 2232.5 cam {solid roller}
Sheet metal intake  {454" plenum}
Custom header  {1 3/4" primary}
Tial V60 wastegate
Tial B50 BOV
Wilson 105MM TB
8  212# injectors
NOS 50 shot  {to spool turbo}
Borg Warner S480 turbo
5" exhaust
Reactor fly wheel
Motor plate is also adapter from 2.3 to SBF, then a JW bell to a 180 short planetary powerglide.
I plan to turn the motor 94-9600 RPM and it should put out around 14-1500 HP.
pintoman
I just do not know what to say,can I have it ----PLEEEEEEASE.
dave1957
too coooooooooool!!!!!!!!!!!!!!
1979 bobcat
1974 red stinkbug
Truly art work.  One question I know the answer to is that it will be a 2.3 motor.  World's quickest and fastest 2.3 PINTO motor.
Why that thing will probably make what 400 - 500 horsepower?   :cheesy_p:
OK,...
Roller Cam??
turbo toy
Thank's for the kind words folks. I'm having fun again building this thing. Trust me when I say you have to make everything for this type motor. The car will be a 240" dragster and the motor is kept at 2.3 liter and alky fired. It is my intention to be the worlds quickest and fastest 2.3 Ford at a little over 200 MPH and mid to low sixes. Not too shabby for a PINTO motor huh?
Bill, since it's an alky motor, no IC is needed.The hard part is keeping enough heat in the motor for it to run right.
Map, :showback:
Ya!!!! The craftsmanship is incredible. I ammmmmmm Impressed.
No FMIC??
Using the adapter plate to brace the turbo: LOVE IT.
map351
That looks chinese! Did you get that on sale from Harbor Freight?
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
turbo toy
The little stack is the waste gate exhaust.
Scott Hamilton
WOW!!! What can I say??? WOW!!!!
Too KEWL for words... Awsome!!!!
