Many Parts Listed Below
Date: 04/20/2018 11:15 am
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Date: 05/28/2017 03:20 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
Date: 08/05/2018 01:58 pm
Date: 11/14/2019 04:02 am
  • Online today: 367
  • Guests: 231
  • Total: 231
Gear ratios
Started by Ponygal, October 17, 2007, 09:35:56 PM
Every Pinto/Bobcat I have ever owned has had either a 3.18 or 2.79 rear (until I changed them).
earthquake
IIRC my 78 is geared either 2.98 or 3.00
Quote from: Ponygal on October 23, 2007, 10:25:05 PM
Awesome, found out I've got a 3.18 via door code. Thanks guys!
Hey Ponygal,
Most automatic Pintos are 3:18 rear geared....
Has anyone seen anything lower than 3:18 in a Pinto NUMERICALLY??
Ponygal
'77 Sedan "Gladys"
2.3L auto - swapping to T-5 2009
Dark brown, saddle interior
Supertrapp, Grant wheel, more mods on the way...
PonyGal,
   Place a brick or equal size peice of 2 by 4 in front of and back of the front driver wheel so the car won't roll. Lift the rear passenger wheel off of the ground with a floorjack. Place the shifter in the neutral position. Rotate the tire around once (marking it is helpfull) while counting how many times the drive shaft rotates. Multipy the number of driveshaft revolutions by 2. Then write :1 to the right of that sum. It should look like this X.XX:1.  That is your gear ratio.
Look on the drivers door pillar.
There should be a fixed sticke that has a code.\
from Pintony
Bipper
To get the undercoat off the tag you can try spraying with carb or brake cleaner several times, letting it soak in and wipe off.  Another way is to take the tag off and heat it up with a propane bottle to get the undercoat soft then it should wipe off. A wire wheel on a grinder motor will also remove the undercoat.
Bob
71 Sedan, stock
72 Pangra
73 Runabout, 2L turbo propane
Ponygal
Aside from the diff tag, are there any other ways to tell the gear ration in my '77? (mine is coated in undercoating ewww)
'77 Sedan "Gladys"
