1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 02/21/2017 06:29 am
Date: 02/28/2018 09:33 am
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
door sills
Date: 03/14/2020 03:20 pm
74 pinto
Date: 09/11/2016 06:32 pm
Date: 12/26/2016 04:29 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
  • Online today: 502
  • Guests: 487
  • Total: 487
Cleaning vinyl
Started by Smeed, October 14, 2007, 04:01:16 PM
Smeed
I ended up using some tilex mold and mildew remover. That did the job pretty well but I need to do another application. Ill keep my eye out for Wesleys when I can pick some up.
'73 runabout
Please NOTE that Wesleys IS STRONG!!!
Not recomended for shiney painted surfaces.
Probally be ok if sprayed on a wet rag to clean the steering wheel.
But the vinal, U can use straight out of the bottle.
Easly takes paint off the bottom of hoods-engine bays if left on too long.
A quick spray and scrub and then rinse.
Do small areas, 1 at a time.
I cleaned the Green Pintos engine bay with wesleys with NO problems..
But I cleaned a 1979 orange Pinto engine bay with it,, The engine bay was "MOSTLY" factory black primer after that....
Keep the hose handy to wash off asap.
Smeed
Ill look into both. The front seats and steering wheel still need something more powerful but most of the other stuff is pretty clean.
'73 runabout
Quote from: Pintony on October 15, 2007, 10:52:22 PM
I think wesleys MAY have lye in it.
No the Westley's company is pretty honest :lol:
Yeah It's got lye in it.
I use "Wesleys" Bleach White to clean almost everything!!!
Dirty greasy blocks, dirty engine bays, interior vinal.
Tires, Vinal tops,
I use it in small sprays and a tooth brush to get the grime out of the texture in the factory Pinto seat inserts
Used weatherstripping??? IT works GREAT on that!!!
Not sure if it will bleach carpets so BE CAREFUL.
DO NOT USE NEAR OR AROUND POLISHED ALUMINUM
I ruined a set of brand new wheels 1 time
Once you do get it cleaned, use some of the Meguires Gold Glass Vinyl and Rubber Protectant. It gives your interior a slight sheen but not slippery at all like amour all does. Plus it doesn't fill in the pours of the plastic and vinyl letting them dry out and crack.
Smeed
The sun got it pretty bad. The car came from New Mexico. The back seats and that area isnt bad though, Ill hit that stuff with some clorox.
I cleaned what I could with some armor-all and it got the light stuff off but the front seats and steering wheel is going to need something a little heavier.
'73 runabout
Soap & water. You could also try Clorox Cleanup for the tough stuff. Use a rag, wet it in soapy water, wring it out, and scrub. Viynl is tough stuff, if the sun hasn't dried it out.
Smeed
The vinyl inside of my new pinto (camera died, will have pics if anyone cares :P) is in need of a good cleaning. It looks like there are mold or mildew stains on it and Im not sure what to clean it with.
'73 runabout
