1972 pinto grill
Date: 02/27/2018 12:13 am
Date: 02/14/2018 01:34 am
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
Date: 07/17/2018 09:22 pm
postal pinto
Date: 06/03/2020 09:31 am
Date: 07/10/2016 10:17 am
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Electrical
Date: 03/29/2017 11:37 am
  • Online today: 533
  • Guests: 459
  • Total: 459
How To RE-PAIR Fiberglass Pinto fan shroud
Started by Pintony, October 12, 2007, 08:22:22 PM
This funky apparatus is what I needed to hold the parts until the epoxy dries.
Here is a bad break and a crack that is partially hidden by the Caution sticker.
Here is a 2.0 shroud that I took off a complete wreck of a Pinto.
It is in 4 pieces and has varrious bits missing...
When I am done it will be as good as new.
That is my Puppy Roxie,,, She loves to hamm  it up!!!
Here is the repair from the other side.
After running over with a file and a coat of matte black paint the repair will be as strong as the original and quite un-noticeable.
Here is the repair after sitting overnight.
The tape just pulls off leaving a slight texture...
I use plain old masking tape to form a mold for the epoxy.
I use JB WELD and It is self leveling so U have to prop the part the correct angle to get the epoxy to stay where U want.
I have tried the putty type epoxy.. I have to say it "I do not like it for this kind of repair...
Here we have a part torn out on the mounting area...
Notice how I scuffed the area around the dammaged part with 80 grit sandpaper...
Here R some photos of the early Pinto fan shroud.
The first one had some cracks and a broken piece.
These cracks occured while changing a starter...
Remember how I said to jack the engine up?
Well... I forgot to check 1 little detail.
The 2.0 has a 2 blade fan.
                                                      NOTICE!!!!!
              Make sure the fan is NOT pointing straight up B4U start jacking engine. :'(
Anyway the 2nd shroud had a BIG piece missing up top.. I'll bet the same thing happened???
Hello Group,
I thought I would do a segment on how to do some repairs on the Pinto fiberglass fan shroud.
These repairs will go from Mild to Wild.
