Date: 10/03/2018 10:46 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 08/22/2017 09:21 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 11/04/2018 02:34 am
Pinto hubcap
Date: 01/07/2017 08:40 pm
Date: 06/24/2020 06:12 am
  • Online today: 529
  • Guests: 450
  • Total: 450
hints fo starter removal
Started by zolorg, September 23, 2007, 10:06:17 AM
All right :lol:  I removed the header and unbolted the starter and it slipped right out.  No issues.  I think it was removing the  header, sure beats messing with the steering....
I will let you know.  As of know I have the car up on jackstands but it is raining and since I have to work in a real air condition garage It is on hold until the weather breaks.....
Hello Jim,
If your head pipe is off the starter removal should go easy...
Quote from: Pintony on September 24, 2007, 02:42:49 AM
Jacking the engine is the easyer way on the early Pinto...
IF U do not know the "TRICK"... of turning the starter backwards B4 removal.
it looks like the starter is coming out of my 75.  So i gather from this the best way is to take out the motor mount bolt and jack up the motor?  I won't have any exhaust in the way so does all this still matter or am I dommed???
I have the same problem. My hands shake too, in anticipation of getting the job done right and taking that baby for a spin. Ya!!!
zolorg
Thanks for the tip, actually replaced with a starter with a factory original from, a mustang II my father-in-law had pulled from a parts car that he had.   We did check the lubrication, and brushes all were amazingly good, hardest part as keeping the starter still to get the bolts started.
Quote from: WagonNut on September 23, 2007, 05:53:35 PM
What Pintony said works. But before I knew that tip, I removed the motor mount bolt and jacked the motor up a little on the starter side, This helps greatly to  get the starter out.
That is what i do every time.
Let me just add a little tip here if I may....I personally never trust the amount of lubrication that is put into a remanufactured or rebuilt starter. When I bring home a starter from the parts store I take it apart and do two things or maybe three. First I see to it that the bearings have enough grease in them to squish out just a little bit when assembled. I also make sure the bendix helical spline is well greased. Then when the body is back together I check that the engagement contact will not make till the bendix it just 1/8 of an inch from being fully extended. Then I make sure that the gaskets are placed just right as so water won't  get into the starter.
zolorg
Pulled the steering rack worked great.
turbowagonman
I did the same exact thing!!!!
zolorg
Thanks for the tips, that makes it easier than just guessing what the the best method of removal is.
WagonNut
 :welcome: zolorg,
On the 78 Pinto, drop the rack and pinion a bit by removing the 2-3 BIG bolts from the rac-pinion slide the bolts back a bit and the rac will lower to allow access room for the starter to be removed.
This does not hurt the alignment as the rack will just re-bolt in the same position.
DO NOT REMOVE THE TIE-RODS...
\From Pintony
zolorg
Restoring a 78 Pinto need to replace or rebuild the starter are there any tricks to removing the starter the clearance looks very tight. starter is original but is locked-up.  Not sure weather to rebuild or replace?  Can't really complain after car set for 20 yrs in a field.
