1976 pinto for sale
Date: 01/12/2017 02:08 pm
Seeking parts
Date: 10/18/2020 10:35 am
72 Pinto
Date: 03/07/2019 12:07 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Date: 06/25/2021 12:59 am
Pinto Watch
Date: 06/22/2019 07:12 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Date: 03/17/2019 10:15 pm
  • Online today: 489
  • Guests: 288
  • Total: 288
Aftermarket wheel offset
Started by hoots, May 27, 2004, 07:24:07 PM
bricker4864
I run 8" in the back without a problem. I think i'm a fuzz over stock width.
It all depends on your back space. I think I've got 4" now, but there's room for 5".
With the additional width from the 8.8, you should fit more than that.
madmike8
I just bought a nice '80 Bobcat... I think I'd like to do the Granada Front disk swap, which if understand correctly moves the wheel outwards 3/4" per side. Then use a 86-93 Mustang 8.8 modified for leaf spring setup. The 8.8 is 2" wider than the Pinto rear, or a inch per side. With the extra width I'm hoping that I can get 17x8 Bullitt wheels with 245/40/17 tires to fit under the Bobcat.
I know I need to nail down all my measurements first... but does that sound reasonable?
BTW... This is my First Post... So... Howdy Folks!
"In this world you must be oh so smart or oh so pleasant. Well, for years I was smart. I recommend pleasant."
Elwood P. Dowd
pintoman
      I'm using 15x8's from a 86 saleen on my RALLYE with out using spacers.I'm also using 225/50/15 tires.
WVBobcat77
Tell them it's for a 4 lug mustang.  That'll open up some avenues.
Bill in WV
1977 Bobcat
1978 Pinto - V6 Sedan
Farmboy
   Where are you guys getting your custom wheels at?  The tire shops in my town just keep telling me to go to the junkyard.  I guess they don't want my money!!!! ???
74 Pinto Wagon
71 Runabout (parts car)
MR GASKET sells both 1/4" and 5/16" thick four lug spacers. Their on the internet.
CHEAPRACER
Quote[Then, once you get the 1 inch spacers you need the wheel will be hanging out too far, and unless you intend to raise up the car and hang the tire outside the fender
And that definitly went out in the 70's
vbmdu
I recommend not using spacers if you can help it. I dont think they would pass tech inspection if you race either. You're certainly putting more stress on the lugs and bearings.
 15x10 with 5 1/2 will not work. First, the back spacing to too big, your wheel will be rubbing on the spring, not to mention there is no room for the tire. Then, once you get the 1 inch spacers you need the wheel will be hanging out too far, and unless you intend to raise up the car and hang the tire outside the fender this combo will not work ( on a stock car) however it would work if you tubbed the car and shortened the rearend.
c0rn_d0g
I'm getting some magnum 500's for my pinto...at least i am going to unless anyone knows of a problem. the fronts will be 15X7 with 4 1/4" back spacing, the back 15X8 with 4 1/2" back space. Will they fit on my 71? and is there any chance of 15X10's with 5 1/2" backpsacing fitting on the back without heavy mods? i imagine they would hit the e brake cable and inner fender...any help would be appreciated. thanks.
Don't the 71-73 vehicles require a different offset than the 74-80 vehicles.  My 73 hatchback has 15x7 Centerlines ( I don't remember what the backspacing is).  They fit fine and do not rub with the plastic liners removed.  However these wheels do not fit my 79 wagon without rubbing.
Bricker, what year car are you running the 8's on?
pbwagon
Thanks, I ordered some off ebay, and they are on their way 8) ;D
1980 Pinto wagon with 1971 front end
hoots
Universal bolt pattern, 4x4.25 anf 4x4.5
about $23 total.
pbwagon
Quote from: hoots on May 31, 2004, 08:24:58 AM
I got them on ebay, they were 19.95 plus shipping.
were they for pinto's specific or for mustangs as well? and how much did you pay?
hoots
pbwagon
Quote from: hoots on May 29, 2004, 08:37:11 PM
I picked up some 5/16" spacers and going to get some 15x7 rims.
where did you pick up your spacers? I need some :)
bricker4864
I think that you can only fit 4" of backspace on the front wheels of a pinto with stock brakes. I have a set of six inch wide wheels with 4" back space and a set of eight inch wide wheels with 4" bs. Both work fine, maximum width is determined by how far you want your wheels to stick out from the car. 8" is still under the fenders.
hoots
pbwagon
could wheel spacers be used to help with a wider wheel?
hoots
What's the widest 15" wheel that will fit on the front of a Pinto?
