Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 10/10/2019 10:02 pm
Date: 06/19/2018 03:58 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Date: 02/18/2017 05:52 pm
Date: 07/21/2017 11:49 am
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
  • Online today: 382
  • Guests: 363
  • Total: 363
turbo swap questions
Started by dholvrsn, September 13, 2007, 10:35:50 PM
Quote from: dholvrsn on September 14, 2007, 10:29:52 AM
...Tell me about these TPS and IAC...
You do know what they are and what they do, right.....?
If not, put the wrenches down and step away from the car.
...Can you really redrill the engine mounts to down it 5/16" for more hood clearance?...
NO, I did not re-drill the mounts, I re-drilled the engine mount BRAKETS. Also mentioned in my thread, the 79/80 might need less work to get the needed room, but you might still need to grind a little off the T/B and linkage.
My turbo has six bolts with three clamps holding the snail shell down.
More questions:
Will this fix the stock throttle body bell-crank from hitting the hood?
Quote from: dholvrsn on September 13, 2007, 10:35:50 PM
...How many types of 60mm throttle bodies are there? Which ones work on a 2.3? How do you modify these to work on a 2.3?...
Why do you want one of those? The stock T/B only becomes a restriction once most of the others are dealt with (porting of the head and manifolds, 3" exhaust,....). Lots of people out there making 300+ RWH with the stock T/B.
As far as what types, try to get one that takes the same TPS and IAC; that should make it easier.
IMHO: Put it all in as stock, get it running well, THEN start upgrading (ported parts excluded). If you keep it all stock it will let you trouble shoot any problems you might have, and you won't need to try to figure out if it is an "upgrade issue" or an "install issue."
i had a garrett on my '71 , a T-04.  all you have to do is loosen the band clamp (on that model) and rotate it to the position that you prefer and tighten the band clamp again.
How hard is it to rotate the compressor housing on a Garrett turbocharger without breaking any seals and things?
What kind of linkage connects the clutch peddle to the clutch cable? Do any other Fords use the same item? Anybody have one that they would sell really cheap?
