Date: 03/21/2017 07:47 pm
Date: 03/17/2019 03:57 am
Date: 02/28/2018 09:37 am
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
Date: 11/12/2020 08:28 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Pinto Watch
Date: 06/22/2019 07:16 pm
  • Online today: 481
  • Guests: 266
  • Total: 266
Mustang 4 link in a Runabout
Started by vonkysmeed, May 24, 2004, 09:52:23 PM
vonkysmeed
The idea was a thought.  We have moved on to a Mustang II rear end.  That was a lot easier so far.
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
Tobey
Quote from: claudermilk on June 21, 2004, 08:48:19 PM
That was a concern, but since we have one...
Now I'm thinking just use the lower links & fab up a Panhard bar (if I'm remembering the live axle parts correctly) for lateral control.
BTW, anyone know what the Foxbody axle width is?  The car isn't handy for measurement right now.
I'm a little late with this, but you would need both lower links, one upper link, and a panhard bar.  Don't forget about some reinforcement for the upper spring perch; might as well do coil-overs.
claudermilk
fomogo
Mustang 4 link is actually not a great design... if you like turns.
The anglrd links bind up pretty bad.
A tru parallel 4 link would be a much better choice.
Jim
www.turbopinto.com
width wise it will fit, however i've never seen it with the mustang set up, i'm sure it can be done.....if you can weld and fabricate or you have lots o $$$ ;D
vonkysmeed
Stop me if you have heard this before,
Has anyone tried and  accomplished installing a Fox body mustang rear end into a Pinto runabout with the 4 link still in tact?  I know that there is some major reworking to be done to do that, but is it possible?.  I already have removed the tank, but will not do any cutting of the car until I have a mustang that will sacrifice its engine, trans and rear end and have determined that it is possible to do that installation.
73 Pinto Runabout
6 point cage
