73 rear hatchback glass
Date: 07/06/2017 11:33 am
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Squire trim
Date: 03/28/2018 10:11 am
Date: 07/17/2018 09:49 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Automatic transmission
Date: 02/13/2021 02:52 pm
Electrical
Date: 03/29/2017 11:37 am
Date: 02/05/2017 09:45 am
looking for parts
Date: 06/19/2020 02:32 pm
  • Online today: 586
  • Guests: 102
  • Total: 102
Metallic flake from transmission dust cover
Started by dave1987, August 27, 2007, 06:00:48 AM
When the starter-drive moves forward it comes in contact with a spacer that is made of a soft material
"MOST LIKELY BRASS" this is the WEAR section of the starter W/O this washer the starter drive would grind into the flywheel.
Maybe the reason you were changing the starter anyway???
I first noticed this when I had to change my starter a few weeks ago.
There is some type of metallic flake (either gold or brass) that was on and around the shaft area of the old starter and the bell housing dust cover.
I'm wondering if this is from me down shifting from to high of a speed in the past (when I first learned how to drive a stick) or is it from my pilot or release bearing going out??
I haven't had any problems with drive-ability of the car, starting out or once it's going.
