'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
Date: 09/15/2019 08:30 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 06/12/2018 08:18 pm
Date: 04/20/2017 08:56 pm
Date: 06/30/2018 09:48 am
V8 rear end
Date: 04/12/2018 10:57 am
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
  • Online today: 529
  • Guests: 507
  • Total: 507
wiper knob and bezel
Started by dholvrsn, August 19, 2007, 10:19:50 AM
turbowagonman
I think (I might be confused with the Headlight Switch) there is a hole on the Bottom side of the switch, all you do is stick a small punch in the Hole and pull the Knob Straight out. Then you have to have a set of Clip Ring Pliers or Snap Ring Pliers (I forgot exactally what they are called) to remove the Nut. I believe thats the way it comes out, I may be wrong but I don't have a extra switch to confirm this. So take a look at the under side of the switch and see if there is a small hole and if it does that is the way it comes out.
If not, on the Knob there is a Square opening that has a metal tab in there pry that towards the Knob and the handle will slide off, then using a Clip Ring Pliers or Snap Ring Pliers you can unscrew the holding nut.
turbowagonman
How do you remove the wiper knob and bezel without breaking them? Thanks!
