Date: 02/27/2017 10:10 pm
Date: 08/03/2017 07:40 pm
Date: 08/26/2018 06:35 pm
Date: 02/18/2017 05:55 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 11/02/2019 10:25 am
Date: 01/23/2023 02:22 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
  • Online today: 586
Front disk for my 71
Started by Thunder55, May 19, 2004, 08:48:16 AM
ChrisV
Disc brakes from newer model Pintos will work, as will Mustang II parts. You'll need the whole spindle, but that should be dirt cheap. If you want, you can get upgraded stuff from various street rod vendors that put larger GM disc brakes and calipers on the Pinto/Mustang II spindles, and it costs way less than that Wilwood stuff.
And stay away from crossdrilled rotors. It does nothing for you except cause more locations for the rotors to crack from. It doesn't help reduce the gassing of pads, as brake pads haven't outgassed since the '60s.
http://www.teamscr.com/rotors.htm
http://www.teamscr.com/grmbrakes.htm
http://corner-carvers.com/altimathread.php.html
I've owned over a hundred cars in the last 25 years.. What the heck was *I* thinking...
c0rn_d0g
I was actually lookin into the same thing about a day ago for my 71. I got this in an email from the Wilwood sales dept-
"Take a look at kit 140-2129-BD ( drilled rotors ).  You will need to change to at least a 15" rim recommended."
again, thats a Wilwood kit. $550 if i'm not mistaken. I think i have seen other kits in summit for a bit cheaper, but the wilwood kit has 4 piston calipers, you can get rilled rotors, and it looks pretty and shiney. Hope this helps.
allfordmark
My stock '72 has original  front disk brakes.  It is quite drivable and the stopping sure.
'66 Mustang
'72 Pinto
'50 F-1 1/2 ton Pick-up
Thunder55
My 71 has drum front brakes... what kind of kit or car can I get to convert it to disk?
Thanks
Bob
Bob
thunder@fordpinto.com
1971 Fiberglass Pinto
466 soon to be 557 ci
(Shooting for the 8's)
http://www.chaseaustin.net/pintos.htm
