Date: 10/26/2020 03:24 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
Date: 02/03/2018 11:28 am
Date: 10/10/2019 09:42 pm
Date: 02/22/2017 01:58 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
  • Online today: 344
  • Guests: 215
  • Total: 215
What rearend and where do I find gears?
Started by pilot7t6, August 13, 2007, 03:38:35 PM
bob55
But it's a nice drive this time of year!   ;D  Glad I could help.
In a quandry......
pilot7t6
Thanks for the info!  Unfortunatly I'm in Kansas so it would be quite a haul to get parts from you.  Now that I know what I'm looking for, I'll see what I can wrangle up in the scrap yards a little closer to home.
bob55
You do have the 6 3/4, you're correct in that the 8 inch is like the 9 inch with the carrier dropping out of the front of the housing.  An 8 inch out of a Mustang II is a direct bolt in, and depending on your location easy to find.  I converted my 8 inch to five lug using Moser axles, the stock Pinto rear brakes, and mid-90's Ford Ranger brake drums.
Where are you located?  I have a complete 6 3/4 (unknown ratio) I'll give away, and also have an extra 8 inch housing and 4 lug axles I'll sell for $100.  I don't have the ability to ship these, so it would need to be a local pickup.  I'm located in Marysville, WA, approx. 50 miles north of Seattle.
Bob
In a quandry......
pilot7t6
By bolt in axles, I meant the axles are held in place by the for bolts out on the end of the tubes.  The differential itself comes out the back of the housing.  I take it from your explanation that the 8 inch is like a 9 inch where the ring, pinion, spiders and all are on the carrier which comes out the front?  Mine all come out cover on the rear, I guess that means a 6 3/4?
bob55
With the bolt in axles, does the "pumpkin" bolt into the front of the housing.....ie no bolts on the back of the axle housing?  If there's no bolts on the back of the housing you have an 8", and gear ratios are plentiful.  For 8" ratios, check out Jegs or Summit.
In a quandry......
pilot7t6
Hello!  New guy here.  I was looking for some lower gears for my 1980 hatchback with the 2.3, problem is I not sure what rearend I have.  It has bolt in axles, and a rear cover and the spiders all enased in the housing.  I'm sure you guys can tell me what it is, but is there any way to find some lower gears for it like 4:11's or so?
Tad
