Date: 02/18/2017 04:47 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Date: 07/03/2025 04:35 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
  • Online today: 500
  • Guests: 329
  • Total: 329
hole in tunnel
Started by hellfirejim, August 02, 2007, 07:25:24 PM
turbowagonman,
PM returned
turbowagonman
Jim, pm sent.
turbowagonman
turbowagonman
I'll get back to you either later tonight or tomorrow with a complete price!
turbowagonman
Strange, I replied within a couple of days....  ???
anyway 60112.
turbowagonman
Yes, I replied on Aug 8th. I need your Zip code so I can give you a complete price.
turbowagonman
turbowagen
Did you ever get the PM I sent you?  Ii do want the wiring?
UPDATE:
Just to update everybody, I found the female plug behind the controls and unfortunately it had the male plug but only 6" of wire. ["clip,clip" :mad:]
Fortunately Rick is sending me a plug that I need and I am going to get the wire harness from Turbowagonman.
Thanks for all the help and there WILL be more questions.
Thank you for the kind offer of the reverse light pigtail.  Looking at the wiring I would say I most likely I will need it.  I thought about a junkyard plug but this is not round more of an oval.  Looking in the engine compartment and I see the speedo cable laying across the back of the block.   :o   :text_yb_warning: yeah the electricals on this car are going to be fun. ;D
My shop manual for the car should be here in a couple of days.  I will let you know then.
Thank you I appreciate it.
turbowagonman
Both of my 80 Pinto Wagons had that Hole and a wiring harness. I cut one down for the T-5 Swap, but I have a extra 4 spd. one. The plug end, I agree that it plugs into a Grey plug under the dash, but for thr Four Speed it's only for the Reverse Lights no Clutch Saftey Switch. Neither of my 80's (last year of production) had a Clutch Saftey Switch.
If you need the Reverse Light Switch Wiring Harness let me know.
On the block off plug, all you have to do is measure the Dia. of the hole and use a rubber plug to fill it. If you cant find any go the the JY and find one in an Engine Compartment of any car that has the same Dia. and use that one.
turbowagonman
Well i ordered today a Haynes manual and it should get here in a few days.  Hopefully it will have the definative answer....  or not.  : )
The 77 Pinto 4spd I got from Jane has the harness on the drivers side floor, and it goes up and over to the right side of the tranny.
Let me look at the 74 i am parting for the plug the floor on that side is shot but i will look.
Phils toys
Update no plug sorry.
First thanks for the replies.
Now if I understand all of this, the early cars [71-73???] did not have a neutral safety switch.
The C-4 and C-3 used the hole for the neutral and reverse pigtail on the driver's side.
The 4 spd cars had the pigtail on the pass side and used a blockoff plug.
Does anybody have a block off plug?????
Every car that you get always has an OH $h8T area and I think mine is going to be the wiring.  Looking at what has been done and how it has been done I know I am going to need a wiring diagram for my 75.  I have a feeling it is going to an adventure when I get the battery in and put the juice to it.
Any and all help is appreciated.
early cars with a manual trans didn't have a neutral safety switch.
Here are a couple pictures from my Cruising wagon.  The harness plugs into a gray connector that is behind the jockey box.  I also included a picture of the spare C3 harness I have.  Hope this helps some.
The C4 has the connector on that side, but the 4spd has it on the other and the harness is much longer for it. I can't remember where it is on the C3.
I just had to look... both the 77 and 80 autos have the plug and hole.
is kind of a weird place to put it...
Quote from: Cookieboy on August 02, 2007, 09:32:45 PM
no hole like that on my 73 4spd runabout... hmmmm...
That is because the original Pinto would never run a wire through a hole near the drivers foot!!!! ;D
Heyu hellfirejim,
Those are great photos and a great question.
Sorry I do not have the answer for you.
This is great info for the group.
Good question i do not have a clue.  I need a wiring diagram...Does anybody have a picture of what is supposed to look like?
That is where the neutral saftey / reverse light pigtail harness goes thru.  That harness is needed so the car will start.  If it is not connected, the starter will not engage.  I have a spare harness for an auto car but not a 4spd.  I was told they are different.  I assume someone bypassed it on your car?
on the driver side of the tunnel down by the accelerator pedal is hole.
First picture
Second picture is a close up.
looks factory, is it?  if so does anybody have the plug for the hole and would be willing to share????
75 runabout 4 spd car.
thanks
