Date: 04/08/2018 05:47 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Date: 12/26/2016 04:29 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Date: 09/06/2020 01:57 am
Date: 02/03/2018 11:28 am
  • Online today: 553
  • Guests: 203
  • Total: 203
Turbo EFI Fuel Hookup?
Started by 77turbowagon, July 30, 2007, 10:27:52 AM
turbowagonman
Simple, cheap and easy!
The right way to go in my opinion.
turbowagonman
77turbowagon
I gotca. That sounds like a winner to me.
turbowagonman
No, I did metal line to the Rubber Hose that connect to the Fuel Rail/Regulator and metal line to the Rubber Hose that's connected for the Return Line. I never even need to remove the plastic clips, either side.
turbowagonman
77turbowagon
So you went metal line all the way to the pressure regulator?
turbowagonman
This is what I did on my first Project Pinto (my second one also, but it's not on the road yet), where the rubber line goes down to the steel line (on my donor car) I cut the steel line leaving quite a bit of extra Steel line. I then put a double flair on the line with the correct fitting. I then just put new Steel line on my Pinto connecting it to the "Remenance" of the Steel line from my donor car and just used a Female Union to connect the two lines.
turbowagonman
77turbowagon
What have you turbo guys done to connect the Pinto fuel line to the 2.3L turbo EFI line? The merkur engine is coming out in a few days to be put into the '77 Wagon. I got all the wiring figued out last night so we're on a roll. I'm sure there are a few more little minor things to contend with but I'll deal with those but for right now I'm just wondering what you guys did and used to connect the old and the new fuel lines. I know I'll have to upgrade the old rubber lines to fuel injection capable lines. Thanks for any help that can be given.
