New cam
Date: 01/23/2017 05:11 pm
Date: 09/15/2019 12:38 pm
Date: 03/21/2017 07:47 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
New cam
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 02/05/2020 11:06 am
Date: 10/11/2019 11:13 am
  • Online today: 802
  • Guests: 251
  • Total: 251
Engine Advice: REbuild or seek new engine
Started by FESPERMAN, July 26, 2007, 12:41:26 PM
FESPERMAN
Flushed engine and still runs like crap.  Of well
FESPERMAN
I took it down the road just noe and it bogs at 55.  I till not go any faster if I dropped it out of an airplane.  I think it is probably toast.  I will get a compression test and see what is up. I have run two cans of carb cleaner down the carb, change plugs and wires with no help.
neal martin
Look at the plugs, that tells a lot, tightening the head bolts won't work. It's probably the gear you have, my 72 is the same way.
Try to find somebody that can build a progressive linkage for the carb. that way both barrels open at the same time, used to know a guy that built them but he's not around any more, that will make a ton of difference.
FESPERMAN
So do I need to do a carb rebuild to get the ports clean?
Is there a good product to run in the car to clean out the inside of the engine and carburetor?
OH and I was wrong a 7 is a 3:40 rear gear According to the parts book.
Check your rear axel tag to be sure.
From Pintonyu
 Hello FESPERMAN,
When you check the valve cover bolts you will find that they are only finger tight.
Do the easy stuff first try tightning the V.C. bolts first and then try a new gasket.
also the cam seal may be tired.and leaking a few drops.
The stock 2.0 Pinto is no power-house but time can TAKE A TOLL...
Most likely gunk in the exhaust ports from the old formula gas.
The 2.0 really suffered when they went from 9.0to! C.R. to 8.2.
My 71 has the stock engine with an auto tranny and it is quite peppy.
My 72 is a bit on the slow side.
Remember untill you get the 2nd barrel open, your engine is breathing through a hole about the size of a quarter.
Try running a marathon with your mouth closed and a peanut M&M in 1 nostril. :D
I am sorry to say that Cookieboys sugestion will not work for you as
IF??? your head gasket is leaking oil then you will still have compression on all cylinders.  I doubt that this is the case .
again keep us posted on what U find.
Quote from: FESPERMAN on July 26, 2007, 04:06:16 PM
It is leaking about a quarter size spot of oil everytime I drive it. I will likely change the head gasket.  I am going pull the valve cover off and see of it needs to be tightened on that corner.  Only one corner is leaking (front/left).  Maybe it needs to be tightned down.
sounds just like mine but I was leaking more in the middle below the intake. The head bolts on the 2.0 are the "stretching type" so you will need to purchase and install new ones when you replace the head gasket. Cost was $35.00 for the head bolts and YES!!! you should replace them. I too hoped I might just be able to tighten mine up and that would work... EVERY!! mechanic I talked to said don't bother, waste of time. Also the guy's here on the group I think agreed tightning was not going to work. Looks like you'll be replacing the head gasket.
here's the link to my oil leak/head gasket issues
click the link--> http://www.fordpinto.com/index.php?option=com_smf&Itemid=56&topic=5752.msg34973#msg34973
It is just real sluggish in the low rpms and once I get it higher than it seems to be fine if keep the rpm's up.  Not expecting alot of power, just more when I start off.  That is what I mean by sluggish.
Again... this sounds just like me. I was talking to Pintony last night and he believes, because of the door code for the rear end, I have 3.18 gears. He said they are hi-way gears and if I understood correctly (sometimes I don't so I could be wrong) based on what he told me I now think I know why I don't have a lot of power at take off but it's good at higher RPM's. Even my newer pinto's (77 and 80) act the same way, slow off the line but OK at the upper RPM's
FESPERMAN
It is leaking about a quarter size spot of oil everytime I drive it.  I have changed the plugs and wires but that was not much help.  It is just real sluggish in the low rpms and once I get it higher than it seems to be fine if keep the rpm's up.  Not expecting alot of power, just more when I start off.  That is what I mean by sluggish.
"If" it were me.....
I would do a compression test and see where that is at.
If the head gasket is leaking and causing compression loss on any cylinder expect it to be sluggish because your only running on 3 cylinders. I had an "oil leak" at the head gasket on my 73 2.0 and it wasn't causing any loss of compression so a leak may not cause compression loss.
If you are loosing compression on any cylinder then consider doing a replacement of the head gasket to see where you stand. Also when you have the head off, if you know what to look for, you can see if there are any potential issues w/the head and pistons. After the head gasket has been replaced test drive to see if you get better power and do another compression test.
That's where "I" would start... there are still a lot of other things to consider but I would start here first.
If you are not losing any compression you then move on to points and/or distributor, carb, plugs, wires, etc... basic stuff. My bad distributor in my 2.0 was causing power issues and after replacing it helped quite a bit.
Another thing to consider is.... stock 2.0's are not power houses, mine is rebuilt, bored, header and all new parts... and it's still not really all that powerful. This part all depends on the person giving the description. I like lots of power you can get from the newer cars... I don't expect it from my 73 2.0 but sure would be nice. Then comes the consideration of manual vs auto tranny...
FESPERMAN
I have a 73 Wagon with a 2.0.
The headgasket is leaking in the front left corner.  There is also a possible leak in the fuel pump.
The car seems pretty tired.  May need a rebuild.  If I take and replace the head gasket and all the other gaskets, I am not sure if it will make a much of a difference.  Thoughts?
Maybe the carburetor needs a rebuild to make it less sluggish.  It is not bogging, just real sluggish.
What engines can be swapped in with not alot of modification? Is it worth just having this engine rebuilt?
