Date: 02/05/2017 09:45 am
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
Date: 01/19/2020 09:06 am
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Date: 06/18/2018 03:47 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
78 windshield trim
Date: 02/01/2020 08:46 am
Pinto brake booster needed
Date: 05/08/2021 09:00 am
  • Online today: 2,457
Holley carb
Started by little thunder, July 25, 2007, 11:47:17 AM
little thunder
I called Holley tech line, they refered me to a guy in Florida who has a cure so I called him, has no web site heres his name and number
  Scotty  Mclendon @ Mclendon Carburators  (813)972-5394
he seems to be quite knowledgable on the subject. It's a kit and comes with a spring loaded needle,speacial screw,4 gaskets and an accelerator pump cam, it works and he has the kit in stock. I figure if Holley refers him he must be pretty good. Thanks for all your tips though.           little thunder
CHEAPRACER
I Had the same problem in a fiberglass roadster drag car.  There is a fix within the pin underneath the squirter but it's been too long ago to remember. Check with The The Carb Shop. 1461 E. Philadelphia, Ontario, CA 91761. Phone: (909) 947-3575 Fax: (909) 947-7495 ... I believe they are still in business and are the ones that can help you.
little thunder
Thanks for the input guys,sorry it took so long to get backto you. Computer was down for awhile, phone line problems, it sucks man. Thanks again and we'll try the jet thing I guess.
                             little thunder
neal martin
Had the same problem with mine on a 2.0 in a stock car, block off one of the squirters, didn't notice any difference in performance.
We were on a 3/8 banked asphalt track turning about 8,000 rpm at the end of the straightaway.
Hello little thunder,
U need bigger jets is you carb is pulling fuel from the squirter.
little thunder
Anybody have a cure for shooter syphoning on 350 2/v. I've got the pullover shooter but that did'nt help much. Any suggestions will be helpful. thanks,  little thunder
