74 pinto
Date: 09/11/2016 06:32 pm
Bumpers
Date: 07/06/2018 04:47 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
1972 pinto grill
Date: 02/27/2018 12:13 am
Date: 01/12/2019 10:19 am
Date: 08/13/2021 10:39 am
Date: 10/27/2018 03:30 pm
Date: 12/26/2016 04:29 pm
Date: 05/15/2022 11:36 am
  • Online today: 367
  • Guests: 230
  • Total: 230
coil question...
Started by Cookieboy, July 25, 2007, 12:09:32 AM
All my running cars are EFI, so I still can not help on your normal coil temperature.
The 77 Pinto also uses the resistance wire to the coil for normal running +12V supply to the coil.  The start +12V supply uses a standard wire.  The transistorized ignition module just switches the coil ground on and off like points do.  I do not have experience with the Pinto ignition module but believe the above the functional test could be done.  Instead of rotating the engine to where the points are closed, just disconnect the coil's negative wire coming from the ignition module and then ground the the coil's negative terminal.  The rest of the test should work to determine if the resistance wire is still there.
Oopss... I forgot to mention it's the 77 wagon, 2.3, auto
not the 73
sorry
I do not have a running points car to check the coil temperature for you.
If the coil is okay and the temperature is above normal, the only thing I can think of is that the resistor wire was replaced at some time with a standard wire.  Did you have to do any rewiring in the engine bay?  If it is not obvious, a functional check can be done.
  • Rotate the engine till the points are closed.
  • Disconnect the large starter cable from the soleniod on the inner fender.
  • Turn the ignition switch to run and measure the coil's positive terminal voltage (low voltage side).
  • Turn the ignition switch to start and measure the coil's positive terminal voltage again (wait a few seconds for the voltage to stabilize).  Could just jumper the appropriate soleniod terminals to simulate a start.
The coil's positive terminal voltage should be higher during starting than during normal running due to the resistor in the run circuit.  If your resistance wire has been removed, an after market add in resistor could be installed (one of those ceramic looking block types).  The resistor wire resistance is between 1.1 and 1.5 ohms per the manuals.
Carb guy was looking at my car the other day and noticed the coil was quite hot, to hot to touch as a matter of fact. Wasn't ambient tempature of the engine compartment, nothing around it was that hot. Hood had also been up for quite awhile while we check things over. He suggested I get a new one. So I did and installed it and still gets really hot...
Is this normal? I don't think so...
Any ideas what could be causing this?
