Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Date: 09/26/2019 05:31 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 10/11/2019 11:13 am
Date: 03/30/2021 12:29 pm
Date: 08/01/2023 06:53 pm
Pinto drive train
Date: 06/29/2018 08:32 am
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
  • Online today: 531
  • Guests: 139
  • Total: 139
Tire & Wheel Size question
Started by messipj, July 24, 2007, 08:48:01 PM
2point3turbo
Make sure they will fit as far as your spindle goes(or whatever its called). 16" TC rims will rub the top of the assembly. They are pretty deep rims as well and if your new ones are even deeper then they will not work.
messipj
Hi Bill
According to the tire calculator web site the 255/50R16 is
26" in Dia.
82.5" in circumference
10" wide
Taking a ruler and measuring the car it appears they will fit.
Hoping to hear from a few members who have more experice with these larger tires.
Thanks
Paul
What is the diameter and the width of the tires?
messipj
I found a set of 16 x 7 4 lug wheels with good 255/50VR16 tires mounted.
Offset measures  about 4 3/4"
Will these fit on my Pinto wagon front & rear???
If the tires are too big, will the wheels fit with a smaller tire??
Will I need a spacer block on the lugs???
Thanks
Paul
