Date: 10/26/2020 03:24 pm
Date: 12/04/2018 07:40 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
$300 Pinto for sale
Date: 04/19/2017 10:24 am
TWM Intake
Date: 08/15/2018 08:20 pm
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
Date: 10/31/2018 12:00 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
  • Online today: 481
  • Guests: 291
  • Total: 291
Pinto clutch Tech. info 1600cc Pinto
Started by Pintony, July 20, 2007, 02:05:22 AM
Hello Group,
This article will deal with presure plate and disc for the ford Pinto.
Please make note.
These transmissions are commonly refered to as the "Hummer" tranny.
This transmission has a cast-iron case with an aluminum bell-house and tailshaft.
The 1.6L or 1600cc Pinto has a 7 1/2" clutch and 2 different clutch plates.
1. English transmission 7 1/2" 7/8 W/20 spline disc.\
2. German transmission 7 1/2" with 1" 23spline disc
The 2.0 uses./ German
1. 8 1/2 clutch with 1" 23 spline disc.
The 2.3 uses./ German
Possible swap?
Merkur XR4TI uses aT-9 tranny very simular to the hummer but has an overdrive gear.
All above transmissions use 90wt gear oil.
Other info I thought might be of some help for swapping into a Pinto.
The MII with the borg warner 4speed " aluminum case
8.5" with 10 spline disc same as the later B.W. T-5 tranny except for in the SVO Mustang with uses a 9" clutch with the 9" 10 spline disc.
These trannys have an aluminum case and use ATF for lubricant
