Date: 12/13/2016 10:25 am
78 hatchback
Date: 03/12/2023 06:50 pm
Wagon hatch letters
Date: 12/31/2023 04:24 pm
windshield
Date: 04/14/2018 08:53 pm
Date: 03/05/2017 03:27 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
Date: 04/20/2017 10:10 am
Date: 10/10/2019 09:42 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
  • Online today: 600
  • Guests: 296
  • Total: 296
Interesting discoveries today in the yard...
Started by orangerunabout, May 02, 2004, 12:36:22 AM
pintopaul2003
hey go back to the yard and see how the doors are i'm still looking for a good set for a sedan . pintopaul@bluemoo.net
we have a new addition to the pinto family
Hunter Daniel born nov 21 2006  5lbs 12.2 oz                     pintopaul@verizon.net
OK maybe I'm seeing things too... My pan on my Pinto has 11 bolts. SUPPOSEDLY the trans came from an '83 Cougar XR-7 turbo. considering what y'all are saying, mine can't possibly be a C4, but if it isn't the pan is lying. I know this trans came from a turbo cause I had to change the vacuum modulator. it wasn't leaking and worked great at part throttle, but refused to shift except at redline at WOT. so I'm assuming it was designed for boost rather than vacuum.
BTW pop out windows aren't unusual , especially on later models. they were a common option
orangerunabout
Actually, I'm building a 2.3t pinto and got it for myself lol...
Everyone said that after 75 they did not put the 2.3/c4 combo in any pintos, so I posted this to show that they actually did.
Check out the internets only Turbo Pinto forum
www.planetboost.com/pinto
if its a C4, they are rare on the 2.3  Everyone seems to be looking for them. I would buy it, you could sell it on turboford.org ,  here,  They are in short supply.
orangerunabout
Found a 1980 pinto in the yard today, went to look and see if it was an auto and it was (I needed a shifter and linkage for my C4.) So out of curiosity I popped the hood and saw a 2.3, I was curious if it was a C3 or C4 so I crawled under it to count the pan bolts and counted 11. Thought i was seeing things so i counted 2 more times and still got 11 then had a buddy I met up there double check. Turns out, it was a 2.3L pinto with a C4 made in 1980 (the trans code was "W" so it was actually factory equipped. It also had something else weird, the back windows were like the ones on minivans, they popped out.
Just thought I would share with everyone that may be looking for a C4 and/or bellhousing.
