  • Online today: 535
  • Guests: 504
  • Total: 504
Accelerator Pump screws
Started by dave1987, July 12, 2007, 02:03:40 PM
I've collected screws from several things I've disassembled in the past. I happened to have four longer screws of the same thread pitch which worked just fine. no more gas leak!
Redeless1
Sure you can tap it. You may get by with a nearly same diameter, but in an SAE thread, as they are metric in the 5200
1971 Mercury Montego "Cyclone" wagon 351C Toploader Detroit Locker 9
1972 Pinto Wagon 2.0 aspiring turbo car
68 Cougar 351W Toploader
78/79 Cougar
89 SSP Mustang Texas DPS
Because Different Is Good!
The on the bottom accelerator pump screw holes are stripped on my Holley 5200. Can I fix this instead of getting a new carb? Can I just re-tap the holes and put slightly larger screws in? It leaks a little, but not horribly out the bottom seal for the pump.
