Date: 09/15/2019 12:38 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Date: 07/30/2020 11:45 am
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
  • Online today: 600
  • Guests: 282
  • Total: 282
Door latch "studs"
Started by FlyerPinto, July 02, 2007, 03:09:16 PM
blink77
NOW THAT IS A GOOD LINK!!!!!
FlyerPinto
$5 each? This just keeps getting better and better...
1977 Bobcat HB
1977 Bobcat HB
1978 Pinto Cruising Wagon
I must have ben very lucky when i changed mine , the moved  but did not drop. Also i picked mine up at the local parts store in the help section for about $5 each.
Phils toys
FlyerPinto
So while I'm not completely hosed, I'll be digging a bit. The other door (passenger side) closes just fine now though, so it will be worth the effort. Also, having the drivers side door pull tied to the emergency brake handle does give the car something of a classic look. God I hope no one takes a picture of this...I'll never live it down. But thanks for the tips, I'll give it a go as soon as I can and let you know how it works out.
1977 Bobcat HB
1977 Bobcat HB
I have never had that happen with the strickers, but I have had that with the door hinges.
What Blink said.
blink77
YOU MIGHT HAVE TO TAKE THE SEATBELT ASSEMBLY OUT TO GET
TO THE PLATE. IT SETS IN 2 TABS. THE PLATE NOT THE BELTS.
MINE IS IN THE BOTTOM OF THE QAURTERPANEL-AS WE SPEAK.
THE INSIDE TRIM IS OFF, BUT I CAN'T GET MY HAND IN TO
GET THE PLATE BECAUSE OF THE BELTS. THE PASS. SIDE WENT
ZIP-ZIP. I THINK, MAYBE THE DIRECTION YOU TURN THE STUD OUT
ON THE DRIVERS SIDE, ROCKS THE PLATE OFF THE TABS. NOW JUST
TELL ME IT'S THE OTHER SIDE AND I'LL ADMIT TO JUST NOT BEING
CAREFUL. GOOD LUCK, BUT IT'S NOT REALLY THAT BIG OF A DEAL
IF YOU'VE GOT THE TIME TO WASTE, LIKE I MUST HAVE.
BILL
FlyerPinto
The studs that come out of the door frame of the car (78 Cruising Wagon) were a little chewed up on my car. So I went to the Ford guys and bought replacements (about $25 each, not cheap) and went to work. The first one was easy; the old one came off, the new one bolted right in and the door fit better than it has since I've owned the car. Yee-ha! Especially since the car is outside as my garage is being worked on and I know the doors leak as there was water on the floor mats when I checked it the other day. The second one was more difficult to get off, and when it came off there was a bit of a clunk. The receiving end of the assembly has dropped away from the frame, leaving nothing to bolt the new assembly into. Anyone ever encounter this? I'm thinking I'm might be able to get to it by removing the inner panel along the back seats, but I don't recall. As I'm currently outdoors with this and am working solid for the next month, I need to get this thing fixed in a hurry. Any help would be appreciated. In the meantime, I'm going to put a tarp over the car tonight. Thanks.
1977 Bobcat HB
1977 Bobcat HB
