New cam
Date: 01/23/2017 05:11 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Date: 08/01/2018 01:27 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 08/06/2021 02:23 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
  • Online today: 548
  • Users: 1
  • Guests: 235
  • Total: 236
  • Wittsend
HELP ASAP!!!!
Started by 78squirewagon, June 16, 2007, 10:33:30 AM
I got it to running again but  rough. It has a backfire now. It almost sounds like a plug is crossed or not firing. is there a trick to setting the timing? The Chiltos manual I have is pretty useless.I am going to work on it later when it cools off outside
I may have to take you up on the distributor if i cant get this one going
earthquake
Good luck I hope it all works out.I have a reman sittin here for a 77 $15.00 plus shipping,Sorry I know it's not much help rite now.
So this is not something I am supposed to be able to do by myself? Looks like I may be in trouble. The wires going to the connector look pretty bad and i know that you can get replacement stators at Checkers. I will see if i can get it back together
earthquake
Hey Mark
    I have one sittin in my lap rite now,and lookin at it you would need to remove the rotor from the shaft.Next there is an e clip located on the plate opposite the pickup remove this,remove the screw retaining the wires and lift it off.Thats all there is to it.The pickup is not meant to be removed,the hat clips would be impossible to get not to mention the tool to install them.Let me know if this is what you needed to know,I'll check back soon.    Doc.
I am trying to replace the stator assembly (magnetic pickup) on my 1978 wagon with the 2.3L. I have everything down to the pulling it out and cannot figure out out to take it off the distrubtor. I cant get the armature to come out.
PLEASE HELP ASAP. I need to get it back togther for a show tomorrow
