Date: 01/23/2017 07:41 am
Date: 04/28/2018 04:12 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 11/11/2019 04:49 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 09/21/2018 11:35 am
74 hood
Date: 07/03/2017 03:46 pm
  • Online today: 452
  • Guests: 312
  • Total: 312
PINTO COMPRESSION FOR A 2,3L
Started by PintoCDN, June 13, 2007, 03:23:48 PM
Starliner
It's usually more important to look for pressure variation from cylinder to cylinder.  If they are close and you have no oil burning issues it may not need to be rebuilt.   If you add too much oil it can act as a filler, not only a sealer which can raise the compression ratio.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
PintoCDN
Thank you,
I must rebuild engine. In fact I found two sites witn kits to rebuild at a very decent price.
Cheers,
JGC
earthquake
I believe it should be between 175 185 lbs depending on the year.
earthquake
PintoCDN
Thanks,
What will be a normal compression for that engine?
Jean
earthquake
135 to 140s a little low.Adding oil and getting a 50 to 60 psi jump indicates it needs to be rebuilt.Your head is sealing but the rings are leaking down.
PintoCDN
Hello,
I checked compression for my 78 Pinto and it is 135-140 lbs. Is it a normal value for that engine as with the oil addition test thru spark-plug holes, comp. raised to 190 lbs.
Thanks.
Jean
