Front grill for '72
Date: 03/02/2022 12:09 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 01/04/2017 04:07 am
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 04/20/2017 10:10 am
Date: 11/23/2017 05:44 pm
pinto for sale
Date: 09/11/2016 09:47 pm
Windshield
Date: 01/15/2022 09:31 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
  • Online today: 600
  • Guests: 527
  • Total: 527
factory mag question
Started by dholvrsn, June 13, 2007, 09:48:25 AM
turbowagonman
I didn't mount them for that same reason!
You could go with a spacer and remove the Zirt Fitting (grease fitting).
turbowagonman
Update: I got the wheels and they do mount with regular mag lug nuts. However, the fronts scrape against the upper A-arm ball-joint. So has anybody successfully mounted these wheels on their Pinto and lived to brag about it? How did you do it?
billnall
Regular chrome lug nuts, same as Pinto would have had on it.
Ford Parts Man
If you have them already, just take a look at the lug nut seat (the part where the lug nut would come into contact with the wheel).  If the edge is chamfered (at about a 45 degree angle to the face of the wheel) and the hole is only slightly bigger than the stud, then it takes the standard conical lug nuts.  If the edge is square (no chamfer) and the holes are quite a bit larger than the stud, then it takes the mag type lug nuts.
Good luck!
--Doug
I had an 86 Turbo Coupe with those wheels.  From what I remember, they used regular chrome lug nuts.
I just got a set of Ford factory turbine mags of the '80s Mustang style for my Pinto. Does anybody know if they use regular chrome lug nuts or do they take any of those goofy shouldered specialty mag types?
