sport steering wheeel
Date: 10/01/2020 10:58 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Date: 02/28/2024 02:07 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Date: 04/10/2017 07:30 pm
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Date: 05/19/2018 04:56 pm
Date: 09/03/2018 08:58 am
  • Online today: 802
  • Guests: 288
  • Total: 288
Junkyard performance.
Started by zkit18, June 08, 2007, 03:04:53 AM
duffro
I have been learning as much as I can on this subject as I am building a couple of race cars on a real shoestring budget.  See 24hoursoflemons.com .  The GM enthusiasts have gotten this down to a science, I just built a hot rod '65 Buick and you can practically throw Camraro brakes and suspension at the thing and have them stick!
-So far I have fitted my Pinto with an SVO motor and gearbox.
-A Mustang II 8" rear axle with mini spool
-Later model larger calipers, Though I hear that the Granada setup is the way to go, but then you have to switch to 5 lug wheels.  Any of the 8" rear axle 5 lug axles will work but if you buy the GM pattern Granada rotors and have your axles drilled to match you have a wider selection of wheels.
With a total expendature of about $250!
What I want to figure out is what radiator to use.  I have seen normally aspirated Pintos witht the cheap and available VW Sciorocco radiator, I don't know if this will work for me.  I have also read the v6 Ranger rad is good but the ones I see in the junk-yards look pretty narrow.
Anyone else??
zkit18
Just curious if anyone has thought about starting a thread listing what parts you can get form other makes and models that will bolt in with little or no modification.  Like rear ends, breaks, axels, engines, etc.
74 2.3L Coupe
