Date: 07/17/2018 09:49 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
Date: 08/03/2018 09:19 am
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
oldskool787
Date: 02/12/2017 12:42 pm
Date: 12/26/2016 04:29 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 10/31/2018 12:00 pm
  • Online today: 447
  • Guests: 344
  • Total: 344
!977 Passenger door
Started by Machine1964, May 26, 2007, 09:52:49 PM
earthquake
I have a door from a 76 bobcat it has one small dent or large ding origanal paint no rust complete $45.00 plus shipping.
Machine1964
It's from a hatchback as I pulled it myself.The hinges are slightly different(could only line up one hole on the bottom one)and the top leading edge of the door doesn't quite line up with the '77 front fender right plus there's a body line in it that my '77 doesn't have.
Quote from: Machine1964 on May 26, 2007, 09:52:49 PM
I have a 1977 Pinto hatchback and I'm looking for a passenger door.
Quote from: Machine1964 on May 29, 2007, 11:45:49 AM
...I have a 1980 door on it now and theres just enough difference in bodies that it doesn't quite fit right...
Machine1964,
You may want to check to see if the 80 door your car now has on it was not from a wagon.  There IS a difference between the wagons and the slantbacks.
Quote from: HELLFIREJIM on May 29, 2007, 12:32:29 PM
...I was told this is an Arizona car.
HELLFIREJIM,
To verify an Arizona car, to be a TRUE Arizona car, it should have a DSO code of '75'.  All Ford vehicles, from at least the 60s through the early 80s, that were shipped to the Phoenix distribution point, were assigned a DSO of '75'.  Now this is excluding any special optioned vehicles that were issued a code longer than two digits.
This is not to say that other DSOs were not good, just that it is not a true "original Arizona" car.  I grew up in Tucson, AZ, and I love old Fords, so I've always made sure to know what I had as a baseline.
Oh, and let me tell you what a shock it was to go in the Navy and see the rusty cars in Illinois!  I had never seen a 'rusted out' car in person until then.
Good luck all!
--Doug
I agree.
I have never had any issues as long as I used the correct door pulls and hinges.
The quality those years (or lack of it) might have something to do with it...
quickrick
Thank you Tigger but I have a 1980 door on it now and theres just enough difference in bodies that it doesn't quite fit right.Thanks anyway.
I'm curious, what is the difference?
TYDEKE MOTORSPORTS
Tricky Ricky Chop Shop
(740) 701-2908
Chillicothe, Ohio 45601
Will a 75 hatchback door fit?  It looks like I will be having one available shortly.  It will be complete [glass, mechanisms,door panel, etc EXCEPT hinges] so if it will fit and you can use it let me know.  I am just west of chicago.
PS: Acutally I will have both doors available and I was told this is an Arizonia car.
Machine1964
I have a door off my 80 hatchback.  The door has no rust and factory paint.  It is darn near perfect.  The door is a shell, no glass or door hardware.  I am located in Portland Oregon.  Let me know if you are intersted and I will get you some pictures.
Machine1964
