1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 04/27/2018 10:28 pm
Date: 09/26/2019 05:31 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Date: 09/15/2019 12:28 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Date: 04/10/2017 07:30 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
  • Online today: 802
Hello, just saying "HI"!
Started by fastmonkeywheels, May 24, 2007, 04:37:16 PM
fastmonkeywheels
Good day,
I stopped by to post a want add for a 2.3 front sump oil pan, but I think I might hang around a bit for the tech you guys have here.
I have a 1978 Mustang II Coupe with a 2.3 Turbo out of an 86 T-Bird.  An unfortunate oil pan leak caused me to pull the motor to check bearings.  Thankfully only the rod bearings were a little pitted so I should be on the road again soon.
My 78 is presently stock for 86 TC standards, but that's just so I can start at the beginning.  I'm a software/electrical engineer and have been looking into the Dodge ECU system since most of the Merkur guys around here are running that.  However, I intend to change it up a little and use Ford's EDIS instead of the Dodge distributor.  Should make for a really cheap programmable DIS engine management system.  I know some of you are running 2.3T so that's why I mentioned it.
Take Care!
