Date: 05/21/2019 11:50 am
2 liter blocks and heads
Date: 03/28/2018 09:58 am
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 09/22/2020 11:33 pm
Date: 06/05/2018 09:13 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
Date: 02/05/2020 11:06 am
Date: 08/26/2018 06:35 pm
  • Online today: 529
  • Guests: 249
  • Total: 249
turbo head vs. N/A head?
Started by osiyo59, May 03, 2007, 10:35:26 PM
earthquake
Save the valves from your turbo head.They are special alloys.much better than the stock valves.
ADaughen
Quote from: osiyo59 on May 10, 2007, 09:19:29 AM
I'm in San Jose California. Where are you located? Oh, and Thank you for the offer 8)
I am in Ohio.
'78 Cruisin' Wagon
osiyo59
ADaughen
I have a stock 2.3T head sitting in my garage.  Needs cleaned up and freshened up but it came from a working engine (~88k miles).
I'll let it go for free.
'78 Cruisin' Wagon
osiyo59
I was not planning on just bolting a used head on the motor. It will be gone through by my motor man. I just needed to know if there was any difference in the cores. Sorry guys, I should have been more specific on what I was doing. The whole motor is being gone through and will definatly not be stock. Shooting for 300+ HP. Thanks
tony v
bill is right on the money. i talked to my motor man in washington and he told me that the valve seats and combustion chambers are different. DONT GO with bigger than stock boost. if you run all stock, the performance will not be the same as using a turbo head. like bill said open up the ports and go with the better seats and valves.
Rubber side down!!
There are differences between the turbo head and all the N/A ones, but they will bolt up.
The big differences are the cumbustion chamber and the lack of the EGR ports. I have been told that some of the N/A heads do not have hardened valves seats too, but I don't know for sure on that. That being said, I have heard from a bunch of guys that use a N/A head with no big problems. I would expect that if you keep the boost to stock levels you SHOULD be fine. If it were me, I would open the chambers.
osiyo59
Does anyone know what the differences are between a Turbo head and the n/a head? I need to replace the one for my turbo and need to know if the n/a head will work.
