SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 09/22/2020 11:33 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
Date: 08/09/2018 11:09 am
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Date: 09/15/2019 12:38 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
  • Online today: 553
  • Guests: 307
  • Total: 307
To those running V8's
Started by mrpinto, May 02, 2007, 12:25:02 AM
I am running the stock radiator cooler.
Some aftermarket electric fans are made to either push or pull. Keep in mind that most of them don't push as well as they pull. I have seen where they list the CFM differences, and it can be a lot.
mrpinto
Are you using a trans cooler, or going through the rad? My last rad was an old top tank with no tranny lines, but I swapped in an aluminum V6 Ranger A/C rad with the lines. I still have the transmission cooler, but will it be fine running through the rad?
Also, can run of the mill electric fans be reversed? I was told I can wire them backwards so it will "push". Is this true?
1979 302 Pinto Custom
1971 460 Drag Pinto
