1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Date: 12/10/2016 04:11 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
pinto floor mats??
Date: 01/11/2017 07:27 am
Date: 09/26/2019 05:31 pm
  • Online today: 548
  • Guests: 383
  • Total: 383
Crazy boost??
Started by 2point3turbo, April 26, 2007, 12:27:08 AM
turbowagonman
I had the same problem with my IHI, I was told it was "Boost Creep" and the solution was I had a bad WGA!  :sorry:
turbowagonman
2point3turbo
It is the Garrett so it should handle it ok but it would be nice to be able to hold 17psi all the time. There are no leaks... all new hose with BCS unhooked and bleeder in place. I have the same setup on my Pinto and it works very well holding 17 all day. I am thinking it may be the WGA but it should peg the gauge with the hose off no matter what. The hard thing to figure out is the fact that it goes back down to 10 right after spike.
What turbo? The T-3 will handle 20*+ OK where the IHI has issues over 18*.
Load, gearing, flow and other factors will effect the amount of boost an engine can make and sustain.
fomogo
With the wastegate unhooked it should peg the gauge.
Are you gettin a boost leak anywhere? Check all pressurized manifold connections.
Also be sure the WG is properly closing.
Jim
www.turbopinto.com
2point3turbo
I have a friend with a TBird and when we have a controller on and also with the WGA hose off it will spike at 20ish and drop right back down to 10 and stay there. It should be getting full boost all the time wouldnt it?
