Clutch Cable Needed
Date: 04/03/2017 10:54 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
windshield
Date: 04/14/2018 08:53 pm
Radiator
Date: 05/27/2018 06:07 am
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Seeking parts
Date: 10/18/2020 10:35 am
Date: 01/06/2017 11:42 pm
  • Online today: 535
  • Guests: 467
  • Total: 467
Gear Broke what went wrong
Started by rpark068, April 25, 2007, 01:49:51 PM
krazi
it could be that the weights locked up the distributor and in turn sheared the distributor drive gear. if this is the case, you got lucky. it happened to my 2.8 before I bought it, and it broke the drive gear on the cam instead of the distributor. and I had to replace the camshaft. alot of work. have the distributor checked. replace if necessary.
krazi
yeah, I'm Krazi!
I have seen threads on other forums about the block not being machined correctly.
earthquake
It could have just been a bad gear,if it happens again then worry about it.
CHEAPRACER
Was the engine fully warmed up? Cold mornings make the oil pretty thick.
turbowagonman
I've heard of this happening if you are using a High Volume/Pressure Oil Pump. Is that the case here? Did you use too thick of oil?
When I did my conversion to a 2.3 Turbo I was warned not to use a H.P. or H.V. Pump for this reason.
turbowagonman
rpark068
The Distributor gear literally exploded. The oil pump has no binds, the shaft bearings are brand new, and the shaft isn't bent. What is the reason for the gear breaking I am totally stumped. :wow:
