Date: 02/27/2017 10:10 pm
Date: 04/27/2018 10:28 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Date: 04/13/2018 11:30 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
  • Online today: 548
  • Guests: 236
  • Total: 236
Door seal adhesive
Started by mrpinto, April 19, 2007, 07:19:35 PM
earthquake
They were originally adhered with liquid butyl rubber the new polyurethane would probably also work.
I did not use stock door seals. I went up to the trim shop and bought some stuff that looked like it would work. I used no pins. I used common super glue for placement. It took a while for the seal to mold in place but it worked great, like a refrigerator door. I cleaned the surfaces with degreaser and the superglue is holding like iron and has been on there for five years now.
turbowagonman
Quote from: TIGGER on April 19, 2007, 09:07:41 PM
I use 3m's weatherstripping adhesive.  It works pretty good and gets tacky somewhat quick.
I used the same, GOOD STUFF!
turbowagonman
on my 73 the body shop found the push pins at the auto glass/paint/body supply store here in town and mounted like factory. I do however think that auto krafters (where you "might" have got your gaskets) has the adhesive if you want to go that route.
mrpinto
For those that got aftermarket door or trunk seals, what type of adhesive did you use?
1979 302 Pinto Custom
1971 460 Drag Pinto
