Date: 10/24/2018 07:41 am
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
Date: 08/30/2018 12:59 am
Rear brake shoes
Date: 01/23/2017 05:01 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Date: 08/22/2017 09:21 pm
Date: 12/09/2016 08:34 am
Date: 08/09/2018 11:09 am
upholstery for bucket seats
Date: 10/30/2018 08:44 am
  • Online today: 403
Front clip swap info please
Started by 2.3stangii, April 14, 2007, 11:28:21 PM
turbowagonman
I believe the Bezels are for a '74' to '78'! So any of those grills will work.
turbowagonman
2.3stangii
Well thats one part down, 76 Grill anyone?
78 Pinto wagon
74 Mustang II
78 Cobra II
turbowagonman
2.3stangii, I've got a set of '76' Headlight Bezels with the Chrome Rings. The Chrome Trim Rings have seen better days though. $15 + shipping.
http://s98.photobucket.com/albums/l262/turbowagonman/Parts/?action=view&current=P1020752.jpg
http://s98.photobucket.com/albums/l262/turbowagonman/Parts/?action=view&current=P1020753.jpg
turbowagonman
WagonNut
Better news. You don't need to change the fenders to go from 78 to 74-76 style. You just need to remove the rubber headlight surrounds from the fenders you have and get the 74-76 style flatter styled headlight bezels. I've done this the opposite way. I changed a 76 to a 77. It works.
You will need the grille. There are subtle differences between the grilles in the mid 70s, even tho they look similar.You may need to find a year specific brace/bracket to retain the grille that you buy. Not sure about that.
Hope this helps.
2.3stangii
So all I really need are fenders and grill? That's great, time to start hunting parts.  ;D
78 Pinto wagon
74 Mustang II
78 Cobra II
WagonNut
I have a 75 hood and a 78. They look identical to me. I'm fairly sure that the hoods interchange from 74-78. Earlier hoods look similar but may change around the front latch design. The bumper brackets on the 75 will interchange with the 78. They are a different style but use the same dimension mounting holes in the subframe. I would keep the 78 bumper/mounts because it is similar to the 74-76 but made of aluminum and is much lighter in weight.
Overall, I think that you could easily change your 78 into a 74-76 style, but it is more difficult to fo to 73 and earlier. Hope this helps.
2.3stangii
What about the bumper mounts? Also is the hood the same from 74-78?
78 Pinto wagon
74 Mustang II
78 Cobra II
Hello 2.3stangii,
The 74-76 swap is not too bad except for the bumper mounts.
The swap to the 71-73 style are a bit mor complicated as the 74-up core support and frame are bigger and will not allow the use ofd the front pan unless you cut the pan..
2.3stangii
Not sure if i should put this here but surely I'm not the only one who needed info on this. Say I wanted to change my front clip on my 78 wagon to a 74- 76 or 71-73, What would i need to do? Are the body lines the same for 71-80? And could i change back with minimal effort if i wanted to?
Thanks.
78 Pinto wagon
74 Mustang II
78 Cobra II
