  • Online today: 500
  • Guests: 416
  • Total: 416
Turbo Wiring Harness...Help
Started by osiyo59, April 08, 2007, 01:24:25 PM
fomogo
www.turbopinto.com
2point3turbo
CHEAPRACER
 I see Turbo Joe has a new site up and running offering new $500.00 harnesses made to order, a little pricey but I don't know the time involved in researching or cost in building so I won't criticize.
osiyo59
Thanks you guys, This project would be ten times harder if it were not for the help of every one here. Rob
The 86 and 87 T/C harnesses are VERY different.
Nice info though.
2point3turbo
I would have to say to go through the steps 77turbopinto has posted. I figure if you just follow the few wires, power, ground, and key, you should be safe. I did it all on my own and wished I had there help but I didnt find this site until I was in the tuning part of the swap. Pinto wiring should be kept intact as much as needed. The main thing is to not "splice" into any wiring on the Pinto but to just focus on wiring and the few needed wires for the ECU from the donor to work. Get all the info you can on both cars and read over the swaps already done, then read them again. It is way easier then you think it will be. Do the research and have fun with it. http://www.rothfam.com/svo/reference/87Thunderbird.pdf is a link to the wiring on the Tbird. I used this as my reference.
osiyo59
Thanks Bill,
Anyone else familiar with doing this swap Utilizing the first generation pinto?
I posted a thread as detailed as I could go in the FAQ section.
The problem is, there are differences in the wire harnesses between different year Pintos, as well as different year 2.3T donors.
WARNING: It is VERY easy to fry the ECU and BOTH HARNESSES if you hook things up wrong.
I gave all my best advice in that FAQ thread in the first post. Please read it carefully, lots of info.
I have no idea on the 72 harness.
Check out my thread on Connie's orange Pinto in the "Your Projects" section.
osiyo59
Ok, This goes out to all of you that have done the 2.3 EFI turbo conversion. I finally got around to pulling the motor and T5 out of my 86 donar tbird. I also pulled the main engine harnes and the ECM. The question is Do I splice the original 72 harness into this or do I need any more from the bird? Is there a detailed post from anyone who has done this in the past? Bill? ;) I could really use some advice on this. If there isn't a detailed post please use this thread to post any instructions, tips, dos and don'ts. Thanks...Rob
