Date: 07/20/2018 03:00 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 03/17/2019 03:57 am
door sills
Date: 03/14/2020 03:20 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
Wheel cap
Date: 04/25/2022 11:21 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
  • Online today: 548
  • Guests: 411
  • Total: 411
oil
Started by tlcmbc, March 27, 2007, 07:50:18 PM
tony v
bluefordpinto is right on the money. i lived in pa for 37 years and that is exacty what i recomend with the oil ratios.the miles are what make the big difference, then the weather. its only my opinion. but ive been wrong before.
Rubber side down!!
bluefordpinto
as high horse has mentioned it depends on weather and climate areas, if your in indianna, most likely a 5/30 or 10/30 will do just fine year round, another thing to bring to mind is how many miles are on the motor, anything below 20,000 i would use a 5/20, between 20,000 and 40,000 i would use a 5/30, 60,000 to about 100,000 i would use 10/30. between 100,000 and 150,000 i would use 10/40 anything after that is 20/50. but im from california. really warm here. ive even seen guys run a 15/40 rated for deisel pick-ups at around 140,000.
GET 'ER DONE!!!!!!
Tlcmbc,
   It really depends on the weather range in your area. Summer 20/50 Winter 10/40.
Summer = 50 and above Winter = 50 and below.
tlcmbc
Thanks, I was thinking 10 30 or 10 40. I live in indiana so I will re-think this now
Well, I used 20w50, but I also drove my pinto in Tucson, so it is slightly warm there.  If I remember correctly, with an oil change, I'd put in 5 quarts with a new filter, of course checking it again after the first start up to circulate the new oil into the new filter.
tlcmbc
what weight oil is recomended and how many qts for a 2.3 motor. Thanks
