1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 04/30/2023 04:31 pm
Date: 10/25/2019 03:30 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
  • Online today: 295
  • Guests: 185
  • Total: 185
Adjustable cam gear?
Started by 2point3turbo, March 23, 2007, 11:29:12 PM
2point3turbo
What I am trying to find out is what the desired setting is with all the guys here that have these. I want to make the best hp with 17psi. What are your settings? Here is a pic of what I got.
fomogo
If I remember right, RW has 2-3 adjustable gears.
If its the keyway indexed gear, then you find the position you want and slide it on.
If its the slotted adjustable one, then it should have index marks... and a 0 mark.
Set it at 0 and install it like a normal gear. you loosen the pinch bolts and move it slightly till the degree of advance or retard you are wanting is indicated. Tighten the bots back down and see how you like the new setting.
I like the non slotted/keyed index gear and the 5 bolt adjustables... with my preferance being for the keyed index.
Jim
www.turbopinto.com
2point3turbo
I have an adjustable cam gear and I am not sure how to put it on and set it right. Any suggestions? Its a Racer Walsh if that matters.
