front end parts
Date: 03/30/2018 12:48 pm
Date: 12/09/2018 06:59 am
Date: 08/01/2018 01:17 pm
windshield
Date: 04/14/2018 08:53 pm
Date: 02/05/2017 09:45 am
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Date: 09/01/2017 07:52 am
Date: 09/10/2018 10:41 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
  • Online today: 587
  • Guests: 221
  • Total: 221
oil pan question
Started by dave1957, March 17, 2007, 12:52:32 PM
dave1957
thanks guys got the motor put in last night!!
1979 bobcat
1974 red stinkbug
CHEAPRACER
I used the stock cork side rail gaskets and RTV on the end crank seal parts.
dave1957
thanks for the help guys I'm off to the parts store!  ;D
1979 bobcat
1974 red stinkbug
Or they don't use the Pinto pan, and can't understand why the engine won't fit in the car.
fomogo
If I remember correctly... *brushes cobwebs aside*... use the pinto gasket... just make damn sure it fits properly.
Also... do you have the pinto oil pickup? Some dont think about this till they are doing assembly and the pan wont go on.
Jim
www.turbopinto.com
I would get that one and see.
dave1957
thanks for the info on the dipstick  I called the parts stores and they only have the gasket for the pinto in stock they said they needed to know what month the xr7 was built.. he said they don't make gaskets for it after 2/86...Dave
1979 bobcat
1974 red stinkbug
I use NEITHER.
I cut a section of gasket material to run in the front an rear curves, and use RTV. I do similar with the valve cover.
If you are going to use a gasket, get both and see if they are the same, if not, just use the one that fits and return the other.
BTW: Don't forget to move the dipstick tube.
dave1957
I,m almost ready to put in my engine just have 1 question. My motor is a 1986 xr7..Do I use the oilpan gasket for it or do I use the one that matches the 1978 pinto oil pan?
1979 bobcat
1974 red stinkbug
