WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 07/01/2019 12:23 pm
Date: 07/20/2017 01:23 am
Date: 09/26/2019 05:31 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Date: 08/20/2017 01:34 pm
Date: 07/17/2018 09:49 pm
Date: 01/23/2023 02:22 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
  • Online today: 533
  • Users: 1
  • Guests: 383
  • Total: 384
Help with alternator removal.
Started by EAdams, March 24, 2004, 09:03:02 PM
straw boss
I am not familiar with the 1.6L engine, but I assume it uses a standard Ford alternator.
It sounds to me like the inside of the bolt hole on the alternator has a buildup of corrosion that is preventing the threads from coming through.
Since you have already backed the bolt out enough for all the threads to clear, I think if you just find a way to pry straight out on the bolt head, it will come out.
Some penetrating oil might loosen up the corrosion a little and make the job easier.
Good luck!
EAdams
I have a 1947 Willys CJ2A Jeep with a 1970-73 1.6L Ford Pinto engine in it.  The alternator has failed and I am trying to remove it.  The alternator is located on the drivers side of the engine.  I got the top  bolt off and have unscrewed the bottom bolt 3-4" out but now it just spins in place and I cannot tell that it is moving out at all.  Anyone with a manual or experience????
