1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Date: 09/02/2021 08:21 am
pro stock front end
Date: 06/28/2019 07:43 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Date: 09/15/2019 12:38 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
  • Online today: 905
  • Guests: 563
  • Total: 563
are the doors different?
Started by Felix Wankel, June 04, 2003, 07:03:45 PM
That sounds great.
I have to check the dragstrips rules to see if I can run it at the track.
Thanks
TurboPintoDude
I'd recommend "swiss cheesing" the door, but to keep the window working, use a 1' wide nylon belt with a clip on the end, hook the web into a hole in the glass, use plexiglass if ya really want it light, and screw the clip for the belt in the right position to hold the window closed. Gets rid of about 25 lbs worth of regulator and stuff, and yer window still goes up and down.
I had a pic of this being done, but now I can't find it. The clip goes on the inside of the door about 2/3's of the way down from the top, and he had a lil hook thing on both sides to keep the belt from going lopsided. When the window is down, the clip also keeps the window from falling all the way down in the door. Neat setup, works great, and it's cheap.
Quote from: TurboPintoDude on July 28, 2003, 05:21:45 PM
Dorrs for a 71-73 Pinto won't fit on a 74-80 Pinto, sorry to say
Whats the difference?  ???
I was thinking about getting fiberglass doors for the hatchback and swaping the window frames.
Is this worth the time, or should I just swiss cheese the steel doors? I still want the drivers window to work.
TurboPintoDude
ChrisMiddleton
do yall think the doors off of a 1972 ford pinto would fit on a 1980 ford pinto?
WVBobcat77
The tops of the doors are what is different.  On the wagon, the tops are straight across.  And on the sedan / runabouts, the tops slope downward to follow the roofline.
Hope this helps  ;)
Bill in WV
Bill in WV
1977 Bobcat
1978 Pinto - V6 Sedan
Felix Wankel
Quote from: turbopinto72 on June 04, 2003, 09:37:57 PM
I would not assume that a wagon door will fit a sedan and vise versa. Acording to the fiberglass replacement part they list a 71-76, and with big letters NOT WAGON. I would take it from that that there is a difference.
I've read elsewhere that they aren't the same, but I can't get a wagon and sedan next to each other to compare them.  :(
84 SVO 1E
74 Pinto wagon turbo project
Felix Wankel
I may just buy one, a door there is $27.87   :-\
84 SVO 1E
SVOwagon
I have heard more then once..that they ARE different. Don't know in what way.  ??? Let me know what you find out.
SVOwagon
80 2.3 EFI Turbo Pinto Squire Wagon
91 Mustang LX 5.0 (93 Cobra clone project)
82 Mustang GT (built 460)
89 Mustang LX coupe (built 302)
83 Ranger
http://www.cardomain.com/ride/2167062
Felix Wankel
Is there a difference between the wagon and hatchback doors? My doors are junk, and there are some straight ones in the junkyard, but they are all on hatchbacks.
84 SVO 1E
