1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
convert to stick
Date: 05/19/2018 09:26 pm
74 hood
Date: 07/03/2017 03:46 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
nos core support
Date: 01/03/2020 09:39 pm
Date: 08/13/2021 10:39 am
Date: 05/13/2021 05:29 pm
Date: 02/18/2017 04:41 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
  • Online today: 481
  • Guests: 246
  • Total: 246
72 V8 Pinto
Started by GERBEAR, March 21, 2004, 04:48:12 AM
vonkysmeed
Quote from: 72 V8Pinto on July 09, 2004, 11:04:04 PM
Is there any place to get the part of the mounts that bolts to the block?  I haven't been able to find those... and going to the dealer sounds like a very expensive proposition.
we should probably keep this under the motor mount thread, but  the last time I looked, Ford did not have these motor mounts any more.  Your only hope is either NOS (new old stock) or Ebay.
Good Luck
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
72 V8Pinto
72 V8 Wagon (My 5 year project)
89 Bronco XLT
90 Bronco EB
95 Bronco XL
87 Camaro z/28
vbmdu
Ive heard log style manifolds will fit such as from the first generation Mustangs.
i may try a set of stock shorty headers.....and MAKE them fit with some modifications. Mine seem to not seal too good causing some trouble with my computer (O2 sensors) to read they are running lean.
5.0pintoman
my 78 pinto has the complete motor and t5 tranny out of an 87 gt mustang.I used mustang 2 mounts and oil pan with no problems.The shorty headers would not fit though.
Underdog76
Hey I got the Part #!
it is D72A-6B032-AA
they are both left hand mounts off of a 78 King Cobra
Fast as lightning, strong as thunder
Underdog76
Hey, My dad (Sly Willy) and I just replaced a freeze plug on his 302 so we have the mounts out! I will try to get out there to take a pic or two and I will post the part # (only one # because they are both lefthand mounts from a king cobra).
use V8 mustang II mounts. Motor wise, use whatever you want, late model or early model....from 289 to 351w if you want. No cutting of the inner fenders is nessasary...if you buy the right headers. You can use a small bell C4 from a mustang II with no problem, the bigger one will also fit but MAY require some hammering of the trans tunnel at the firewall. (mine is the larger bell....i had to hammer!)
GERBEAR
 I want to put a V8 in my new pinto but what motor and mounts do I use do I have to do any cutting in the finder well. Plus what kind a C4 tran do I use !  Thanks!!
