78 fender and hood
Date: 03/23/2021 01:07 pm
72 pinto
Date: 06/23/2016 12:40 pm
Date: 01/19/2020 09:06 am
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
Date: 09/09/2018 03:22 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Date: 10/31/2018 12:04 pm
Date: 02/05/2017 09:45 am
  • Online today: 529
  • Guests: 371
  • Total: 371
engine problems
Started by pintoperformance, February 22, 2007, 10:00:05 PM
I agree that it is hard to diagnose without actually being there to hunt it down.  My old 78 broke a piston skirt (found it in the bottom of the pan when we did the rebuild) and it would knock pretty bad.  Typically top-end noises are slower (but higher pitched) than bottom end noises, which is because the cam spins at 1/2 the speed of the crank.  Only things I can think that would wipe cams out would be if your galleries are plugged or a bearing alignment problem.  I always use pipe cleaners to get all the crap out of them when I put an engine together, and A LOT of brake kleen.  Make sure the bearings are installed correctly (get a mirror and check the oil holes to make sure they weren't installed off center or backwards.)  Your head may need to be align honed as well.  Hope it all works out for the best.
--Doug
grgic
My MII 302 automatic, had a cracked flex plate. when i started it up it would knock like crazy after the engine smoothed out(warmed up) it would go away until you put some throttle on it. they crack between the holes that the bolts to the crank go through, you wouldn't be able to see them unless you pull the trans(which it seems like you need to any ways) you could also just have loose nuts on the torque converter to flex plate. pull the starter and check them, they don't have to very loose to make noise.
pintoperformance
flex plate bolts--if loose or missing would the noise stop after the engine warms up?
grgic
Check your torque converter to flex plate nuts or you could have a cracked flex plate(not related to the shifting problem) your description sound like my old MII with a cracked flex plate.
Just a thought
Joe
PintoPerformance,
     Are you sure it's a banging noise? Might wanna try starting the engine without the valve cover on there. It might be piston slap. Has that engine ever been bored? Can you record the sound and post it here for a listen to? Just drag your computer mike out to the garage. Banging in head...Hmmmmmmmmm.
pintoperformance
I have a 1978 Pinto 2.3 engine--here is the problem
When I start the engine it makes loud banging sounds--after the oil get up to the top half of the engine the banging stops.  But when I raise the RPM rapidly it starts again--
I have went through two camshafts that were bad--and they made that kind of noise--but on this particular camshaft I can't find any problems with the lobes shape.
I have performed a test removing the spark plug wires one at a time to see if I can isolate the noise in a particular cylinder but that showed up negative.  Oil pressure runs at about 48 pounds with rpm raised and at about 28-30 pounds at idle.
Does not overheat temp is usually around 180-190--
also my transmission (C3) will not shift up through the gears by itself--I have to manually shift from 1-2-D--but after the transmission warms up it shift by it's self????
Hope someone has some ideas on this..I have very few dollars to fix anything major --and will probably have to sideline the PINTO if it is a major engine or tansmission problem.
thanks in advance.
